Brake Light On Dash On
Old Feb 10, 2004 | 05:41 PM
slp223's Avatar
How do you get the brake light on the dash to go off? the parking brake is not on. are there codes for the brakes like the ses light.
Old Feb 10, 2004 | 05:42 PM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
Hey RJ, Is you fluid level low??
Old Feb 10, 2004 | 06:41 PM
slp223's Avatar
no the fluid level is not low I just did all new brakes ls1's in front all steel lines and on new caliper in the rear. damn things will not bleed out
Old Apr 7, 2004 | 03:21 PM
nathan96's Avatar
I am having the same problem. The system has been bled twice, the light is still on and the master cylinder resovoir does not engage until very late. I have found a hissing noise which I think is being caused by a small hole in the hose the connects the intake to the master cylinder.
Old Apr 7, 2004 | 04:48 PM
buelldevil's Avatar
If the E- break is not on but the light is, you have a low fluid level, or air in the lines. The ABS has its own light so you can rule that out. You may have to bleed the breaks 5 or 6 more times since it appears you have changed calipers.
Old Apr 7, 2004 | 05:23 PM
nathan96's Avatar
I stopped at the dealership and they were talking about 75 to look at the car, so I just bought a motive pressure bleeder.
That shoud do the trick, and it was 46, so I should save time and money both. I am pretty sure that the air must still be in there too, but bleeding over and over again was not what I wanted to be doing.
dluna333
15
Mar 13, 2015 12:30 PM
WildRidez
Feb 23, 2015 07:24 PM
squarehead
Jan 15, 2015 07:02 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
