Brake or Bearing ?
Old Jun 12, 2003 | 10:55 AM
Van5150's Avatar
Brake or Bearing ?
Yesterday I went around slight corner and hear metal type squelch, I applied brakes and noise didnt diminish. Now on and off, mostly around corners I can hear the squelch. I felt the rim after and it was hot compared to the other side. I could not remember if the bearing in the axel would make the rim hot or not, I know a siezed brake caliper would. Any guesses ?
Old Jun 12, 2003 | 11:43 AM
joeSS97's Avatar
Sounds like the bearing.If the brake was dragging you should notice it pulling that way when driving
Old Jun 13, 2003 | 01:22 AM
Van5150's Avatar
My bad, its in the rear axle, not sure if it would pull or not, in front definately pull, but wasnt sure in the rear.
timmy39120
May 2, 2015 05:12 PM
May 1, 2015 01:14 PM
KYWes
Apr 15, 2015 07:28 PM
carl.froehlich
Mar 13, 2015 12:38 AM
