braided steel coolant hoses
Old Jan 15, 2008 | 11:24 AM
94studcar's Avatar
ive got my engine out for a rebuild and previously i noticed that my heater core hose/tube assembly is bad the previous owner did some impressive splice jobs, so instead of paying the huge price for a new one i wanted to run braided steel hoses, and do the same for the rest of the hoses, im also doing away with the ac and egr so i will have a lil extra room does anyone know of this being done or have pictures
Old Jan 16, 2008 | 10:51 PM
94studcar's Avatar
ttt
Old Jan 17, 2008 | 03:32 AM
1982z28with18s's Avatar
Leathal93ta has this done, I will warn you it's a VERY expensive mod.
Old Jan 17, 2008 | 01:42 PM
94studcar's Avatar
is it more expensive than that assembly, because the assembly cost like over 200 bucks if remember
Old Jan 17, 2008 | 02:27 PM
BigBadBlack93Z's Avatar
the hose itself is cheap but the fittings can cost as much as $20 each, and thats for the small ones.
Old Jan 17, 2008 | 03:21 PM
$95.36 wholesale for the GM complete heater hose assembly for a 1994 (p/n 10236039)
Old Jan 17, 2008 | 03:32 PM
mdacton's Avatar
big ones can easily be $70 or more
Old Jan 18, 2008 | 11:45 AM
94studcar's Avatar
thanks for the help i found some fittings at jegs.com that are $13 a piece and the hose it around $30 so i think i can do at least the heater core cheaper than the hose assembly!
Old Jan 18, 2008 | 04:30 PM
z275plus's Avatar
I was thinking about doing the same thing, Post some pix once you get it finished.
Old Jan 18, 2008 | 06:35 PM
94studcar's Avatar
it might be a little bit till its finished the engine isnt back from the shop yet does anyone else out there have pics
Old Jan 18, 2008 | 06:42 PM
mdacton's Avatar
search for them.....that guy has pics...it was several hundred just to do the radiator.
How do you plan to connect the hoses to the radiator?
https://www.camaroz28.com/forums/sho...light=AN+hoses
Old Jan 18, 2008 | 06:51 PM
mdacton's Avatar
https://www.camaroz28.com/forums/sho...d.php?t=544236
Old Jan 19, 2008 | 09:32 PM
94studcar's Avatar
so do you need a special tubes coming off the radiator to use the hose fittings? would these be the right fittings then
http://www.jegs.com/webapp/wcs/store...0002_752556_-1
Old Jan 19, 2008 | 09:40 PM
mdacton's Avatar
There is no way to connect them to a plastic radiator......
If I was you I would just buy the hose shbox listed. Anything more than that is just to much trouble/money
Old Jan 19, 2008 | 09:41 PM
94studcar's Avatar
i think i may get in more than i want to, i may have to stay with the factory heater hose assembly
