Braided ground wire on a 94z
Old Aug 24, 2004 | 11:15 AM
jdizzell's Avatar
I found a braided ground wire hanging underneath on the driver side, anyone know were to connect it to?
Old Aug 24, 2004 | 11:28 AM
94 CAMRO Z28's Avatar
Re: Braided ground wire on a 94z
One end should be bolted to one of the bolts holding the coil on..and the other end should be bolted/grounded to the car right underneath where the CAI would be. Or if you look and see where the hose comes from the radiator on the driver side...there is a bolt right under that on the car "frame".
Aaron
Old Aug 24, 2004 | 11:38 AM
lillbush5555's Avatar
Yes 1 goes to the coil where the other 2 wires are attached..The other side bolts the tha ABS module. The bottom bolt atleast thats where mine is, and I havent ever moved it.
Matt
Old Aug 24, 2004 | 11:25 PM
jdizzell's Avatar
The one that I was talking about is farther back by the oil filter. One end is bolted to the frame next to the driver side door, I wanted to know were the other end bolts to?
Old Aug 24, 2004 | 11:29 PM
i have never seen that 1...sorry man
Old Aug 25, 2004 | 01:22 AM
Lower's Avatar
Mine goes from here -on the coil, to here -a bit below the ABS unit.
Old Aug 25, 2004 | 09:50 PM
jdizzell's Avatar
Thanks for the pics Lower, but my coil on is gounded. The one that I'm talking about is underneth on the driver side by the oil filter. Not long enough to reach the front.
94Z28LS1toLT1
Jul 10, 2024 05:17 PM
Critter
Jul 7, 2015 08:33 PM
Jlo
Apr 3, 2015 10:32 AM
Injuneer
Dec 15, 2014 09:36 AM
kandied91z
Aug 6, 2002 01:18 AM
