boxing in stock LCA's....
Old Jan 19, 2004 | 03:39 AM
simple's Avatar
anyone have any pics of boxed stock LCA's
Turbo Buick guys do this quite often, why dont i see more f-body guys doing it?
i would think it wouldnt cost much more then $20 or so to do it
Old Jan 19, 2004 | 04:03 AM
chpmnsws6's Avatar
i saw a few of em for sale but still notta on testimonials.....
Old Jan 19, 2004 | 04:06 AM
D James's Avatar
I was going to box mine in, but instead decieded the metal was still to weak and prone to bend, so I went to home depot and bought some pipe and welded them inside, now they are overkill, but I figure stronger is better. I would reccomend new bushings, as the stock ones suck big time, I could flex mine way to much. Boxing in your own is very cheap, less than half the price of aftermarket ones. The steel pipe I bought was 4 dollars each and added two pounds to each side. They were a perfect fit, I had to pound them in ever so slightly and they were sized like they were meant for them. Here are some pics http://community.webshots.com/album/83968269vuzDib
Old Jan 19, 2004 | 06:22 AM
simple's Avatar
D James, that is exactly like what i was looking for
you wouldnt happen to know the dimensions of the pipe off hand would ya? thanks man i'm gonna go that route now instead of buying aftermarket, great stuff!!
also do you have any 60ft times to go along with those compared to stock?
Steve
Old Jan 19, 2004 | 06:51 AM
simple's Avatar
i imagine you could do the same to the stock panhard rod also?
just a smaller diameter pipe and obviously longer...
looks like i have something to do now
Old Jan 19, 2004 | 08:45 AM
TQdrivenws6's Avatar
If you guys are looking for some, I have the ones that came off of my car....I will get them to ya cheap!
Chris
Old Jan 19, 2004 | 08:51 AM
mongse_1's Avatar
Boxing in the u-channel is a very cheap and effective way to improve the suspension. If you've got the knowhow, you can also make new LCAs out of tubular stock and rod ends. It's a little more expensive than boxing, but will be adjustable.
Old Jan 19, 2004 | 08:53 AM
You usually will want to replace the bushings too. So by the time you mess with boxing and replacing bushings, you could have bought a set of stout/better aftermarket ones. Yeah, you might come out cheaper doing it yourself and you might enjoy doing that. No problem with that at all.
Old Jan 19, 2004 | 07:44 PM
D James's Avatar
I don't remember the size pipe, I took off one of my control arms and brought it to the home depot, then just found the one that would slip in, like I said though, itis very snug, so after its in. The pipe was some type of plumbing pipe, so there will only be a few different sizes to choose from. Are you welding them in? IF so do slow beads, going cross, at first it messed me up, but soon got it welded good. I suppose you could drill holes and bolt it in, since there are already pre-drilled holes in the arms themselves. A welder would charge very little to do this job. The bushing are bout 40 bucks, so for 50 bucks you've got nice arms, still much cheaper than the aftermarket ones, but don't always look as good. If you have only one car, then, drive down there, and just stick a few different pipes in the arm under the car to see which one it is, also the store can usually cut it and measure it for you for free
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
