Bottom radiator hose replacement?
I need to replace the bottom radiator hose on the driver side on a 95 LT1 that goes from the bottom of the waterpump to the bottom drivers side of the radiator. It seems like it is two different sizes. Is there a way I can get this to work with just a standard size hose or is this gonna be a dealer thing?
thanks in advance
thanks in advance
Re: Bottom radiator hose replacement?
Originally Posted by Mtrhds94Z
GM p/n 10197675
It's 5/8" on one end and 3/4" on the other..
yea I figured as much it was gonna be a dealer thing..
thanks for the info
Originally Posted by shoebox
I would think an auto supply store should also have the correct sized replacement hose.
Originally Posted by InEviTableSS
hmmm you think somewhere like autozone would have a stock sized replacement hose?
should be goodyear pn 63492 , $10.99 list
described as " Bypass - without oil cooler, radiator to water pump "
........under the Hose(Heater) heading in their computer
Has anyone every used An Fittings and Braided Lines from the waterpump to the radiator???
I am going to cut my radiator support and move the car up about 7inches and I need custom lengthed hoses or I may go Braided hose??? Any suggestions?
Magenta_Hearts
Mar 29, 2017 08:54 PM
Magenta_Hearts
Mar 5, 2015 07:01 AM
