Borla exhaust-rapping out??
Old Apr 26, 2004 | 10:17 PM
Bedwellz28's Avatar
Question Borla exhaust-rapping out??
I have a 95 Camaro z28 with a Borla Catback. I recently removed my catalytic converter and replaced with normal piping. Now, when I accelerate in the car above 4k rpm, the car begins to rap out and almost sound like a chainsaw!! At idle, the car sounds really good, but I need a fix to get rid of this. I tried the different plates in the Borla and nothing has worked so far......Please help!!
Old Apr 26, 2004 | 10:22 PM
Barry 94Formula's Avatar
When you take off the cat the Borla basically becomes a cutout. Unless you run the full block off plate I'd put the cat back on.
Old Apr 26, 2004 | 11:20 PM
TheBiz's Avatar
Yeah, what he said.
ZDriver96's Avatar
i did that... i put cats back on the car.
Went dual 3inch car soundcats on a custom 3 inch ypipe. Sounds much better now... 2 3" carsound cats can support over 400rwhp without any power loss. They are 35 bucks each on ebay.
And i stopped smelling like gas after an hour of driving.
Old Apr 27, 2004 | 09:20 AM
Bedwellz28's Avatar
ANY OTHER SUGGESTIONS????
Old Apr 27, 2004 | 12:33 PM
PoorMan's Avatar
Replace the pipe with a bullet muffler.
Jeff
Old Apr 27, 2004 | 12:51 PM
SS MPSTR's Avatar
You have three options:
1. Replace the cat.
2. Replace the muffler/cat-back.
3. Live with it.
Old Apr 27, 2004 | 01:20 PM
CeeBee94Z's Avatar
1. Replace the cat.
3. Live with it.
Yea, there really isn't much you can do about it now....No backpressure does that to ya
Old Apr 27, 2004 | 02:44 PM
GREGG 97Z's Avatar
Jeff
That's what I'm doing, I got the muffler and the ball flange I just need to get it all welded up. Several people are using these as an ORP, it is supposed to take out a lot of the rasp/nastiness withought any power loss. I have SLP headers/Ypipe/ORP/Borla and I dont like some of the sounds it makes now either without the cat.
http://www.jegs.com/cgi-bin/ncommerc...26&prmenbr=361
Old Apr 27, 2004 | 02:48 PM
97; ANN. Z
Guest
Posts: n/a
is the car an auto or stick? after the installation of my O.R. ypipe my borla did the same thing. and after the my stall was put in it went away. the stall keeps it out of the raspy sound area.
Old Apr 27, 2004 | 03:52 PM
z28poweredlt1's Avatar
got the same set up except with the cat, planning on going to a carsound cat or something to get rid of the stocker when i get my header/y-pipe, one of the problems with borla is, your manifolds are so restrictive, and the borla isn't at all, jsut a big cut-out as mentioned before, so you go from a lot of pressure to nothing and the exhaust pops real bad, check and make sure there arent any exhasut leaks anywere along the pipe, even with the cat mine pops a bit more than normal , hoping that my headers over stock manifold theory might be somewhat rightm anyways. theres my two cents.
-Mark
Old Apr 27, 2004 | 03:59 PM
SS MPSTR's Avatar
I'd personally just put a quality high flow catalytic converter back in. I'm not a fan of constantly smelling like raw fuel every time I start my car.
Old Apr 27, 2004 | 04:02 PM
ShelbyZ28's Avatar
That is why I switched exhaust to GMMG from Borla. With my Hooker LTs and no cats my Borla sounded like crap. Like mentioned above there isn't much you can do about it except change exhaust, put the cat back on, or live with it.
-Bryan
Old Apr 28, 2004 | 09:40 AM
Bedwellz28's Avatar
Thanks guys for all of your suggestions. I appreciate it!!
WobblySausage
Oct 7, 2015 02:44 PM
KYWes
Aug 10, 2015 07:03 PM
colts0455
Jul 28, 2015 11:28 PM
Scorch1
Jun 30, 2015 11:24 PM
Beave2780
Jun 12, 2015 07:23 AM
