Bolt size for pulley above AC Condensor.
Old Jun 4, 2007 | 03:20 PM
Silvershark's Avatar
I was curious if anyone had the bolt size for the two bolts that go into the Accessory bracket/pully above the AC Condensor. These bolts are the two that you have to spin the pulley so the gap in the pulley lines up so you can slide them in.
I hope that gives you enough information, I didn't see them on shoebox's site and I forget ken lawerences site address.
Thanks!
Old Jun 4, 2007 | 06:45 PM
mrseven's Avatar
Are you asking for all the bolt specs, as in tread depth and length, or just the head size (socket)? And by the way, I think the "accessory pulley" you refer to is actually the power steering pump.
Old Jun 4, 2007 | 07:22 PM
Yes, it is in fact the power steering pump.
I need the length, thread pitch etc.
I will try the search function again.
Old Jun 4, 2007 | 07:32 PM
Ok, the only info I have found is that they are a 10mm head and possibly a Metric 8. But I have no idea on the length. Any ideas?
Old Jun 4, 2007 | 07:46 PM
M8 x 1.25 x 75
Old Jun 4, 2007 | 09:03 PM
Wow, only 3/4"?
Thanks shoebox!
Old Jun 4, 2007 | 09:17 PM
Originally Posted by Silvershark
Wow, only 3/4"?
Thanks shoebox!
That's not 3/4" it's 75mm! That is almost 3". The bolt is fully metric.
Old Jun 5, 2007 | 01:59 AM
Oops! Thanks again.
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
maybe2fast
Mar 16, 2015 09:45 AM
cyteone
Feb 7, 2015 06:04 PM
