Blue Smoke....
Old Jan 24, 2003 | 01:55 PM
Teal94Z's Avatar
Question Blue Smoke....
Driving the formula today, and I noticed that at idle, and idle only, the exhaust is a light blue color, and smells very very rich. It doesnt smell like oil burning at all, the car runs strong as hell, but I havent gotten it tuned yet. Is this just a rich condition? When I get on it, it has the carbon dark color, then back down to that light hazy blue color at idle...any ideas?
Old Jan 24, 2003 | 05:44 PM
IDOXLR8's Avatar
If you are burning blue smoke then you are burning oil. Keep an eye on your oil level.
Old Jan 24, 2003 | 05:50 PM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
"Am I burning oil?" asked Mr. ignorant. "Are you blowin blue?", asked Capt. Obvious...
Old Jan 24, 2003 | 06:15 PM
94ZRiCeKiLr's Avatar
i agree, blue is oil....a rich condition would produce black smoke if anything...
Old Jan 24, 2003 | 09:46 PM
Teal94Z's Avatar
Thanks for the replies guys, and Captian Obvious...
Old Jan 24, 2003 | 10:30 PM
hvyss's Avatar
As you have already been told you are burning oil. I bet you have an intake leak. I say that because I had the same problem. At idle the car smoked and it had a blue tinge to it. I pulled the intake and found oil leaking into the intake runners of the heads. Changed the intake gaskets and plugs and the problem went away. I think if you change the intake gaskets your problem will disappear. Good luck.
HVY SS
Old Jan 24, 2003 | 10:37 PM
Teal94Z's Avatar
Ya, I am sure I overtorqued the intake bolts, the torque wrench I used was junk, older than I was....I bet that is the problem...thanks
Old Jan 24, 2003 | 10:58 PM
hvyss's Avatar
If I rememmber the torque specs are 35 psi. Don't quote me on that but I a pretty sure. Check the manual it will tell you for sure.
HVY SS
Old Jan 24, 2003 | 11:34 PM
Teal94Z's Avatar
How does 35 ft lbs sound
Old Jan 24, 2003 | 11:43 PM
hvyss's Avatar
Sorry typo error. Its hell to get old.
HVY SS
Old Jan 24, 2003 | 11:45 PM
frmula1's Avatar
Captain obvious passes his shield along to you good sir...
Old Jan 25, 2003 | 12:52 AM
Kain's Avatar
Torque specs on the intake manifold were first torque to 7 foot pounts, then 35ish.
Old Jan 25, 2003 | 09:32 AM
rickyzZ28's Avatar
Also make sure you start with the center of the intake and work you way out.
Old Jan 25, 2003 | 11:00 AM
Trans AM 22502's Avatar
Actually, blue smoke can also be a sign of worn piston rings. Infact, its MORE likely that its the rings going bad rather than the valve leaking. It can be either one, but USUALLy its the rings.
Blue smoke= rings
white smoke= cracked head
black smoke= rich
Old Jan 25, 2003 | 01:14 PM
Teal94Z's Avatar
The car has never smoked before, and I had the intake off 3 times since I finished my heads/cam swap, and the car doesnt even have 50 miles on that combo yet. The last time I had the intake off to fix the leak, I used an old torque wrench that I still think is broken, I tested it the other day, no matter how hard or how many times you turn it, it wont go past 35 ft lbs.....so I think oil is getting into the ports that way....hehe
