Is a blown up LT1 worth anything???
Old May 17, 2007 | 05:20 AM
billsbird's Avatar
....Hi Everyone, I have a '94 LT1 engine & auto trans with 158 K on it that's blown up. I think it's a broken ring. Is the motor & trans worth any money??? Or should I just junk it??? Thanks for any replys, Bill
Old May 17, 2007 | 08:35 AM
Z-RATED94's Avatar
Take it apart and see what's salvageable. Don't throw away the block and crank if they can be used again. If you do the LT1 gods will hunt you down, and it won't be pretty.
Old May 17, 2007 | 11:07 AM
ChevalierSS's Avatar
I recently got about $175 for a dissassembled block, crank, rods, and pistons. It's worth something if it can be re-used
Old May 17, 2007 | 11:37 AM
PartsUnknown's Avatar
Salvage as much as possible. Everything on it can't be blown. What is reusable is worth some money. How much? That depends on what it is.
Old May 17, 2007 | 12:56 PM
billsbird's Avatar
....ok, THANKS Everyone. I will not junk it out then as long as I can get something for it. Plus I'm a little scared of the LT1 gods, LOL! good one!.... Bill
Old May 17, 2007 | 12:59 PM
2000GTP's Avatar
The heads and intake alone can fetch a modest amount of change assuming they are in good shape as well as some of the accessories.
Old May 17, 2007 | 10:12 PM
neil350's Avatar
Its all worth core value if its any good
Old May 17, 2007 | 10:42 PM
buzz12586's Avatar
Someone could always use the block and heads at least.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
