blown + intercooled LT1 1/4 time
Old Feb 27, 2006 | 07:15 AM
hulettsz28's Avatar
Mods are in my sig.
What do you think it will do in 1/4.
Old Feb 27, 2006 | 10:09 AM
buzz12586's Avatar
Re: blown + intercooled LT1 1/4 time
Depends on traction and such. Just go run it.
Cmr0z28's Avatar
4.1 @ 300mph
Old Feb 27, 2006 | 10:45 AM
Sweetred95ta's Avatar
How are you running a blower and 24# injectors? I would think they would max out pretty quickly.
Benji
Old Feb 27, 2006 | 10:52 AM
JustNO's Avatar
24# injectors???
Old Feb 27, 2006 | 10:56 AM
TRYTOTEST's Avatar
Yes def upgrade those injectors to at LEAST 30 lb
Old Feb 27, 2006 | 11:03 AM
OBE1 95Z28's Avatar
A Fuel Management Unit (FMU) bumps up the fuel pressure based on boost level to allow the 24# injectors to flow more.
I think you'll get better responses in the Forced Induction Section of this board.
Old Feb 27, 2006 | 11:24 AM
Ultra_Dog's Avatar
13.172 @ 110.56 - w' 2.16 60' if your tune is half-baked. Subtract another two-tenths with an improved tune and traction.
Your tires will be your main drawback.
Old Feb 27, 2006 | 11:37 AM
sabre81's Avatar
Upgrade those injectors. I'm sure that they are not too happy running at 9000% duty cycle at WOT.
Old Feb 27, 2006 | 11:42 AM
StripedFomula's Avatar
i have similar mods as you. p600b at 8#, 3 core intercooler, 42# fuel injectors, bbk headers, bbk throttle body, borla catback, spec stage 3 clutch, NGK tr6, delteq and thats about it for the big stuff. first time out with the blower i ran 12.8@110 1.9 60'. that was with a tune from PCM forless. it was a good tune just to get it running, but i got tunercat and did some of my own tinkering. leaned it out a little, added some timing...got me to 12.1@116 with a 1.9 60' my IAT's were around 150 degrees with it only being 60 outside, im thinking about getting a fan behind the intercooler, or possibly like a alky injection.
Old Feb 27, 2006 | 12:45 PM
hulettsz28's Avatar
"A Fuel Management Unit (FMU) bumps up the fuel pressure based on boost level to allow the 24# injectors to flow more.
I think you'll get better responses in the Forced Induction Section of this board."
I have an FMU
I am aware that I will need bigger injectors. 36 #'s will be on their way.
Old Feb 27, 2006 | 12:49 PM
Honda Hunter's Avatar
I think a FMU is a band aid. Id get bigger injectors and delete the fmu.
Old Feb 27, 2006 | 02:44 PM
JeffK's Avatar
Originally Posted by Cmr0z28
4.1 @ 300mph
LOL
Old Feb 27, 2006 | 06:19 PM
96camaroSS's Avatar
I saw a very similar combination run consistent 12.5's on BFG Comp T/A rubber. With a best that I witnessed of 12.3XX. The only difference between your's and his was header brand (Hooker) and he had a 2 row intercooler. Trap speed was in the 113-115 range.
FWIW I had better luck running the 24lb SVO's vs. 30's in combination with the FMU. But then I still don't know exactly what/where to tweak with LT1 Edit.
Old Feb 27, 2006 | 06:44 PM
hulettsz28's Avatar
Mid 12's would be nice. I am in the process of buying some DR's and bigger injectors. The FMU will be fine for now, The previous owner had no problems, neither do many people that I have heard of. Yea the bigger injectors would work best, but it should be ok for now. What tune would you reccomend? Madz28 or pcmforless?
