Blown Ignition Fuse??? (Shoebox)
Old Mar 7, 2005 | 08:07 PM
Sweetred95ta's Avatar
I have tried a ton of stuff with my car and can't figure anything out. It stranded me one day and hasn't ran right since. It stranded me because it blew an ignition fuse. What can cause this??? I have tried posting this several times and I get no help. I just need to know what can cause an ignition fuse to blow. I had my car die on me because of it and it hasn't ran since. I replaced the opti and haven't had any luck. Two 02 sensor wires were melted together by the header, but I fixed that. Still nothing. I am getting fuel and spark. What can cause the ignition fuse to blow and after the fuse was replaced, could keep the car from running? I really appreciate any replies.
Thanks,
Benji
Old Mar 7, 2005 | 08:27 PM
Re: Blown Ignition Fuse??? (Shoebox)
The ign fuse powers the coil, ICM and the transmission solenoids. Any problems with those items or their wiring can cause the fuse to blow.
Old Mar 8, 2005 | 12:47 AM
I replaced the fuse and the fired up once, but ran horrible. Hasn't started since. I have since replaced the coil. Is there a way to check and see if anything else is bad? If not, I'm going to pull the opti off and double check it went on right. Thanks for the info though.
Benji
Aug 18, 2015 07:08 AM
Slayer
Aug 17, 2015 03:55 PM
tomfric
Parts Wanted
Jul 30, 2015 03:01 PM
RUNMYTA
Jul 15, 2015 07:50 PM
