Blown headgasket or intake gasket?
Old Sep 13, 2007 | 08:50 PM
ddj19852003's Avatar
I was wondering if there was a method to determine which head gasket was bad passenger or driver? Maybe through a compression test of some sort.
Old Sep 13, 2007 | 09:02 PM
RedWS6TA's Avatar
pull the plugs and see which holes dump coolant.
Old Sep 13, 2007 | 09:18 PM
dangalla's Avatar
leakdown test
and the intake on an lt1 does not carry coolant through it
Old Sep 13, 2007 | 09:27 PM
RedWS6TA's Avatar
yeah a leak down test would work great if he has the tools. or he could just take all the plugs out and have some one crank the engine while he looks and sees what holes shoot coolant out. then he wont have to have any special tools.
Old Sep 13, 2007 | 09:37 PM
94Camaro_Z_28's Avatar
Personally how I would do it.
Old Sep 13, 2007 | 10:01 PM
thanks for the input so fast fellas, my coolant light came on recently and its not dropping coolant anywhere and it will over heat every so often so i have been pouring coolant in the almost every other day for the last week. Now i can even tell me exhaust smells sweet so i guess my gasket went bad.
Old Sep 14, 2007 | 01:12 AM
Ok4thGen's Avatar
i would personally change both head gaskets regardless if you know if one is bad or not, your going to have to take the intake off cross tube on the back of the heads already anyway, just take the time to do them both.
RUENUF
Mar 13, 2016 03:39 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
dfarr67
Apr 10, 2015 07:44 PM
Jazsun
Dec 29, 2014 12:14 PM
