blown head gaskets need help in taking the heads off...
Old Aug 21, 2003 | 06:02 AM
TMD95Z28's Avatar
there are two bolts that connects the water hose to the heads. those two bolts called BANJO bolts. what is exactly banjo bolt?? i tried to take it off, but it was so damn hard. it will turn anti clock wise around 3/4 turn, and just stuck. i tried to turn it the other way round and the same thing happen.
and also, my passenger side heads wont came off, i'd already took out the 17 bolts that connects the heads and the engine..
i saw two bolts that connect the heads and the altenator stand<=== should i took this bolts too?? to take off my passenger side heads???
thanks a lot guys
Old Aug 21, 2003 | 07:04 AM
94_Z28_guy's Avatar
Those bolts connecting the coolant pipe between the heads can be on very tight. Most people leave it alone, then try and take both heads off at the same time with it still connected. I didn't do that, I gently tapped the wrench with a hammer until the bolt came loose.
I believe there are two bolts on the accessory (alternator bracket) that need to come out to get the head off on the passenger side.
Old Aug 22, 2003 | 10:23 AM
TMD95Z28's Avatar
thanks a lot man..
btw do u have to take off the pulley that was in front of the accessry (altenator bracket)???
if not, i think it is really hard to take that on bolt off that was behind the on of the belt pulley..
thanks a lot
Old Aug 22, 2003 | 11:17 AM
FastZinTennessee's Avatar
I took both heads off at the same time, then removed the tube/banjo bolts after I set the heads aside. Worked like a charm.
John
Old Aug 22, 2003 | 12:08 PM
SlowAssTA's Avatar
mine steam lines where easy to take off with a gear wrench, my car had 162,000 miles before i did the heads and cam...
Old Aug 22, 2003 | 12:21 PM
PoorMan's Avatar
I sprayed mine down with PBlaster and used a line wrench. They were tough but not a problem.
Jeff D.
Old Aug 22, 2003 | 12:32 PM
94_Z28_guy's Avatar
No, but I had to go and buy a set of ... I think 45 degree angle..... wrenches to get past/behind the pulley. Of course you could just buy the one you need. Someone might have a better idea to save money, but I spend an hour trying to get that bolt, and after having the right wrench, it took 30 sec.
Old Aug 26, 2003 | 01:54 PM
TMD95Z28's Avatar
thanks man, so what do you call this special tool that have a 45 degree angle???
and i would like to ask about the sensor that was right behind the intake manifold, above the coolant line. it was connected to the engine block not the intake manifold. i broke the sensor, where can i buy the replacement?? i'm not really sure it was the sensor, but to me it look like a sensor for something.
Old Aug 26, 2003 | 05:12 PM
That's the oil pressure sensor. You can get one just about anywhere.
Old Aug 26, 2003 | 06:07 PM
I broke that sensor and got one at autozone......
Old Aug 26, 2003 | 06:10 PM
dreamer1q's Avatar
I cut my steam tube because I couldnt get it off, and used a rubber connection hose when I put it back.
Q
Old Aug 26, 2003 | 10:13 PM
TMDZ28's Avatar
thanks shoebox....thanks guys
it was nice to hear
FYI: i broke that sensor, TMD95Z28 is my friend, and i helped him to do this blownhead gasket fix, and i broke a sensor, that turned out to be an oil pressure sensor......but it is easy to get and to replace....thanks
Old Aug 27, 2003 | 07:58 AM
TMD95Z28's Avatar
it was nice to hear
hey man, its all cool.
btw it is easy to fix and u have to help me man...LOL
and thanks a lot to all the people that gave me some inputs..
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
