Blown Head Gasket
Old Mar 7, 2009 | 12:52 PM
SpeedinZ's Avatar
Blown Head Gasket
So my Z's stock motor finally gave up at 182k on the clock and blew a head gasket. It's going to be getting a new one in a few weeks, I was just wondering what all I should do while the heads are off? I don't have a whole lot of money to spend and I want to keep it drivable since its my dd.
Old Mar 7, 2009 | 09:12 PM
MachinistOne's Avatar
Until you are ready to rebuild the whole motor, just surface the heads and put them back on. I have seen too many oil consumption issues arise after rebuilding heads on very high mileage motors to ever recommend it.
Old Mar 7, 2009 | 11:03 PM
user 647483's Avatar
I suppose it depends if the motor had good compression before the gasket blew.
If the rings are sealing, an H/C install is a great way to pick up some serious power
for your trouble and downtime. Otherwise, I'd just install a good set of 1.6 rockers
and slightly thinner head gaskets for a few extra HP and put the heads back on.
(Have them checked before you reinstall, they may need to be milled flat or replaced if they warped)
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
