Blown head gasket
Old Apr 18, 2008 | 11:43 AM
Savannah Dan's Avatar
Blown head gasket
Blew a head gasket on the way to work Wednesday morning. There was so much steam coming out of the exhaust pipes that 3 lanes of traffic went to zero visibility. Damnedest thing I've ever seen. Is there any way other than pulling the plugs to see which side the gasket blew on? Thanks.
Old Apr 18, 2008 | 11:48 AM
IMHO, if you are going to do one, you should do them both for piece of mind. Maybe not what you want to hear, but just an opinion.
Old Apr 18, 2008 | 12:02 PM
Actually that is what I expected to hear. Guess I just wanted someone to validate what I was thinking. I have the intake off already so I better get out there and get back to it. Thanks.
Old Apr 18, 2008 | 12:19 PM
slomarao's Avatar
change them both while your at it.
Old Apr 18, 2008 | 12:33 PM
94_Z28_guy's Avatar
I agree to do both, but the only thing I can think of is the passenger side is 100x tougher than the driver's side. If its the driver's side you could save time and effort, but the if its the passenger you might as well do both.
Old Apr 18, 2008 | 01:53 PM
Y'all know its going to be the passenger side.
Old Apr 18, 2008 | 11:04 PM
ARZ28's Avatar
doing mine right now and i would not want to take the heads of again.so do them both and dont worry about it for awile.it will save you alot of time in the long run.make sure you get the heads checked to see if they are warped.good luck
Old Apr 19, 2008 | 12:33 AM
SS RRR's Avatar
A plug is the best indicator, but once you pull the heads you'll know exactly where it busted a nut. Especially with that kind of blowout.
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
