Blown Fuse Problem, Help
Old May 19, 2004 | 03:17 PM
havoq's Avatar
Last year an accident happened in my camaro. I have 2 neon lights underneath the seats, controlled by a switch to turn em on and off.
Somehow I was driving and the wires touched one another (ground + positive) I believe and started to smoke and shut off.
I've been recently trying to play with it, and I cant get them to work anymore. I bought a new switch but that isnt the problem. I never had a fuse in between anything either, so the culprit is lying with the fuse panel.
Basically for power, I conencted the positive wire to my fuse panel (battery). I think a fuse is blown between that fuse panel and the batter itself under the hood, but I dunno where to find it !
If I try hooking up my neon lights right to my fuse panel battery, they DONT come on, so I know its something to do with that.
Any advice!?!?
Old May 19, 2004 | 03:41 PM
Dave Feerst's Avatar
first off did you verify the lights still work? do you have a multimeter to test for power at the fuse panel? if the supply fuse was blown I think you would have alot of things not working... check the fuses under the hood and in the car.
Old May 19, 2004 | 04:08 PM
havoq's Avatar
The lights still work ya. I tested them by hooking the 2 wires up straight up to the battery. I don't have a multi meter, but my dad might.
I have already checked all the fuses under the car and on the fuse panel, everything seems to be ok. Weird...
Old May 19, 2004 | 04:11 PM
if there was no fuse in place, or a very high aperage fuse you may have melted some wires. follow the path, a multimeter would really help.
Old May 19, 2004 | 05:15 PM
CeeBee94Z's Avatar
Yea I am gonna go along with this one. If there was any smoke at all then there was way too many amps going through the tiny wires that are running the neons. You should put a small amperage inline fuse in there next time so it blows the fuse first....
Old May 19, 2004 | 07:00 PM
havoq's Avatar
So which wires could it have melted? The neon ones? Power lines? Negative wires?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Jazsun
Dec 29, 2014 12:14 PM
CLEAR
Aug 30, 2002 07:49 PM
