blown 383 costs
Old May 5, 2006 | 09:28 PM
blown383's Avatar
Smile blown 383 costs
I finally got the motor back and here is the final breakdown on costs:
Block machining w/hone deck $300.00
Valve job $110.00
Pressure test heads $ 0.00
Cylinder head resurfacing $ 70.00
SCAT/Probe Forged Rotating assembly $1389.00
Upgrade to 4340 steel crank $250.00
Upgrade to 4340 H beams $120.00
Assemble long block $450.00
Complete balance $125.00
Stroker clearance $ 45.00
Canton 15-242T Pan $283.00
Oil pan pick up $ 34.00
Cut dual key on crankshaft + machine front timing cover for BB hub $100.00
Splayed caps + machine work for conversion $275.00
Stroker clearance $45.00
Gasket set $121.00
ARP head studs & main studs $171.00
Melling oil pump $ 0.00
Crane lifters $155.36
Total labor: $1475.00
Total parts: $2523.36
Total + 8.25% sales tax = $4,206.54
Does that sound like a fair price for a fully forged 383 with the 4 bolt splayed main cap conversion?
How much boost do you think it will handle?
-B
P.S. I forgot that the price included CC 977 springs & seats, Speed Pro Hell Fire rings, clevite bearings, & melling oil pump. They also spent time clearancing the oil pan to clear the dipstick tube.
Old Jul 8, 2006 | 03:36 PM
CALL911's Avatar
Re: blown 383 costs
Sounds similar to my 383 set up. With a few more parts and labor than yours +with installation, mine cost about 7k. Are you planning on running yours on the stock PCM? What do you think you'll put down to the rear wheels?
Old Jul 9, 2006 | 11:53 AM
blown383's Avatar
Re: blown 383 costs
I plan on running the stock PCM.... can't really afford an aftermarket computer at this time. I'll be happy if I can get somewhere over 600hp. Im running a set of LE2 heads and a custom Breat Bauer cam.... We'll see....
-B
Novo
Jun 14, 2016 02:58 AM
Z Power
Sep 19, 2015 11:19 PM
Sep 11, 2015 09:44 AM
Bxlt1
Sep 10, 2015 08:16 AM
blaze309
Sep 8, 2015 05:27 PM
