Blowing trannies - possible fix within
Old Jan 23, 2003 | 04:37 PM
mtxpert's Avatar
Got my car back last night after having some drivability issues with my new transmission (built in late Dec). Basically the car was slipping at full throttle from 2 to 3 shift. I took it back and dropped it off while I was in FL for the ISSCA meeting. Picked it up last night and the shop owner informed me that it had already burnt both clutch packs! He had seen low tranny pressures in a previous 1/2 day drop off to diagnose but he had thought it was my programming so I returned it to stock. Well come to find out:
FIX is here
The wire from the force motor to the PCM and another one was shorted - causing low pressure and slipping.
By fixing the wire it also fixed some other issues I was having:
1. High idle - car would idle around 1500 rpm as I would slow to a stop and then stay there for an extended period of time
2. "Miss" from 3000 to 5500 rpm under load - miss turned out to be tranny slipping/surging as wire shorted/opened
My car shifts solid now - I went with the "back breaker" 3 washer setup and he did the full "heavy duty" treament as he called it. He is warrantying the car for 12 mo / 12K miles with juice
Car also now chirps 2/3 at anything over 1/2 throttle...
If you're going through trannies check that wire!
Mike
Old Jan 23, 2003 | 04:49 PM
FN2BINAZ's Avatar
Do you know what the wire color is? Where was the short taking place? What caused it?
Old Jan 23, 2003 | 05:55 PM
mtxpert's Avatar
I only know the generic details I was given. It was the stock wire that goes to the tranny and it was chafed inside the harness with another wire and they were shorting each other from what I was told.
Mike
Old Jan 27, 2003 | 07:55 PM
Se7ix's Avatar
Did your car exhibit a pulsation at low speed / low rpm in overdrive? Pulsation and vibration at 48 - 60. If you accelerated, did the pulsation / vibration stop? Did you experience vibration or pulsation in deceleration in overdrive (coasting from 55 - 45)?
Obviously, I'm trying to relate my problem to yours )
Thanks for the input.
Old Jan 27, 2003 | 08:01 PM
AZ2ENVY's Avatar
Re: Blowing trannies - possible fix within
Maybe this is the issue we all have been having with missing at high RPM's under load ??????
Old Jan 28, 2003 | 07:46 AM
mtxpert's Avatar
I didn't have a pulse when cruising no. I did have a bouncing idle at rest though. I may have fixed that by opening my TB blades a little - I have a Holley 58MM TB.
Mike
Old Jan 28, 2003 | 08:38 AM
Gripenfelter's Avatar
Thanx for sharing the info.
Help solve some of the LT1 stumble issues.
dylan1303
May 22, 2015 12:24 PM
timmy39120
May 2, 2015 05:12 PM
BigWil
Mar 29, 2015 12:24 PM
siguy
Nov 27, 2014 10:07 AM
MislMan
Jul 19, 2002 11:41 AM
