Blocks
Old Jan 5, 2006 | 09:34 PM
twiztidglory's Avatar
Blocks for 383
hey i am rebuilding my engine out of my 95 camaro, i am woundering your guys oppinions on 2 bolt vs 4 bolt mains. my goal is around 600-700 with nitrous. dont worry im not just talking out of my *** like some may think. i am doing a 383 stroker all forged internals, and i am doing head work on stock heads, i was woundering with that kinda horsepower should i really go out of my way to find a 4 bolt block, i would have to find one out of the corvettes if so and that might get a little pricey. i am trying to go cheap with the block and am not buy new block or heads because i have acess to full machine shop and a good instuctor, i have built one 383 stroker but not to handle this kind of horsepower. i am woundering if you really think i need to to 4 bolt and why. i know its strudier and tougher but if 2 bolt can hold it then ill go with that. i have also seen kits to convert to 4 bolt mains but i dont know if it was for a lt1 or if it even matters as long as its a 350 block. if you have seen a kit please let me know. anything will help, thanks guys.
Old Jan 5, 2006 | 09:55 PM
atljar's Avatar
Re: Blocks
Splay the center 3 and put billet 2 bolts on the ends.
Your shop will need a line hone/line bore to do it
Old Jan 5, 2006 | 11:06 PM
Re: Blocks
buying a sbc 350 one on ebay? suposedly eagle brand. any 350 one will work? i just dont want to buy one and have it be slightly different somehow than lt1
Old Jan 5, 2006 | 11:38 PM
atljar's Avatar
Re: Blocks
Nothing special about them. Standard SBC.
Old Jan 6, 2006 | 12:50 AM
HardcoreRM125's Avatar
Re: Blocks
I wouldnt want to go any more than 500 horses with 2 bolt mains.
The 4 bolt mains help prevent the main caps from "walking." For the extra 150$ in parts and few hundred in machine work, its worth the peace of mind knowing their there.
When I build mine, you can be rest assured I will be converting to 4 bolt mains. Actually, Id like to just build a seperate 2nd engine that way I dont have all the down time in the process.
Old Jan 6, 2006 | 01:02 AM
imnotfast's Avatar
Re: Blocks
I am well above the 500 hp mark with the giggle gas on a 2 bolt studed block.
The KEY is take your time and triple check everything twice...umm thats like 6 times. It is true my all out race block have ProGram 4 bolt center caps with a few tricks done to them. the front cap is a billet one also but only a strap on the rear cap. it holds together very well with NO cap walk.
Old Jan 6, 2006 | 05:17 AM
LameRandomName's Avatar
Re: Blocks
You can make a lot of power and spin a lot of rpms on a 2-bolt main, assuing that your reciprocating assy is well blanced and you do a line bore,
If you DON'T do goot prep, all the bolts in the world wont keep your engine together.
What 4-bolts seem to do is to allow the engine to last longer before running into recip assy problems.
Old Jan 6, 2006 | 05:54 AM
RICEFEDZ28's Avatar
Re: Blocks
Use a 4 bolt.
Old Jan 6, 2006 | 06:18 AM
SS RRR's Avatar
Re: Blocks
Old Jan 6, 2006 | 07:17 AM
BlkLT1Z28's Avatar
Re: Blocks
convert your 2-bolt into a splayed 4-bolt. Not only will the slpayed caps be stronger and better, the 2-bolt block has stronger webbing where the main caps bolt into.
stock 2-bolt< stock 4-bolt< splayed 4-bolt(converted from 2-bolt)
Old Jan 6, 2006 | 09:07 AM
atljar's Avatar
Re: Blocks
Originally Posted by SS RRR
He was asking if they made lt1 specific splayed caps
Old Jan 6, 2006 | 11:56 AM
Re: Blocks
thanks guys. i was a little worried about trying to find a 4 bolt block then remebered seeing conversion kits :-)
Old Jan 6, 2006 | 12:41 PM
imnotfast's Avatar
Re: Blocks
Would totaly disagree with you on that one. Have seen more stock 4-bolt block's crack in the bulkhead area where the 2 bolt blocks live. If this is a max build go to a splayed 4-bolt pinned set up. its the only true was to stop cap walk.
Old Jan 6, 2006 | 12:48 PM
jerminator96's Avatar
Re: Blocks
Why doesn't someone make a billet main girdle like the mustang boys have? I'd kill for something like that.
Old Jan 6, 2006 | 12:51 PM
BlkLT1Z28's Avatar
Re: Blocks
Ive seen it to, but for the most part something went wrong(all the times Ive seen it) but as for the block itself, the strength is all in the 2-bolt block
so maybe
stock 2-bolt~4-bolt....<............Splayed 4-bolt
and I have seen main girdles for SBC and BBC's before, on ebay actually.
