Blocking the EGR
Blocking the EGR
Ok so I have the LT4 EGR Block-off plate (8.49 summit) and I'm wondering on my FLP LT's what can I use to block the EGR Inlet Tube on the header itself? Would aluminum work, duct tape, steel?
Thanks.
Oh and I do have pictures if you don't know what I'm talking about, just lemme know.
phil
Thanks.
phil
On my SLP's I made a blockoff plate out of a piece of 1" wide by 1/8" thick aluminum plate. Home depot sells them, they come 1" wide by 2,3, or 4' long. Just ground out the shape on a bench grinder. If you are leaving the tube on there you could just block it off with some thin aluminum sheet almost like a soda can I would bet. Duct tape??? Don't think that would last too long, it gets pretty hot back there
I wasn't sure if the Aluminum would be able to work, I will give it a try though....lot's of RTV sealant might help!
and Duct Tape cures all - or so I was lead to believe
Originally posted by 94formulabz
I think you were on the right track with the duct tape. After all the header is just a duct for exhaust gasses.
Exhaust manifolds get to ohh, maybe 1200 degrees!!!
Unless there is a new high temp flame resistant duct tape available I don't know about I doubt it would last there very long
the part I got from Summit doesn't fit right, so I don't know if the GM Parts dealers would have the right fit one...but I'm just gonna remove it this weekend and cut all new pieces to fit.
If you use aluminum, using a hard alloy such as T6061 aluminum is recommended. Especially as the header plate is only mounted with one bolt which can flex over time and leak.
Email me or check out my site if you need more help.
Steve
Steve
RUENUF
Mar 13, 2016 03:37 PM
