block screw problem
Old May 10, 2014 | 04:02 PM
turnUP's Avatar
block screw problem
I tried some pb blaster, I hit it with the torch and some candle wax but I keep braking the wrench or adapter. Its square and the 1/4 inch fits with a tiny bit of wiggle. What can I try? How long should I have the torch on it for? Thanks.
Should have put head screw problem.
Old May 10, 2014 | 05:17 PM
Chimera96's Avatar
Re: block screw problem
you talking about the 1/4" NTP fittings on front of block that have alan head?
you would not use a 1/4" ratchet drive on those.....but do use heat (torch) and the correct size alan wrench
Old May 10, 2014 | 06:40 PM
turnUP's Avatar
i just put the pictures up, how long should i heat if for?
Old May 11, 2014 | 09:28 AM
That "screw" is a pipe thread plug in the aluminum head, not the block. Be careful with the "heat".
Why are you trying to remove it? Appears someone deleted the steam pipe from the back of the heads.
Old May 11, 2014 | 11:18 AM
Originally Posted by Injuneer
... Appears someone deleted the steam pipe from the back of the heads.
...or, if it is a newly assembled engine, someone put them on the wrong sides (meaning there are open ports on the front of the heads that now need those plugs).
Old May 11, 2014 | 07:13 PM
turnUP's Avatar
thanks for looking, its not deleted, just never used, it was a display. Yes they are in the heads, I should have put that instead, Im sure Im not using enough heat I wanted to be on the safe side. everything was capped off on it one way or another and these are the last 2.
Old May 12, 2014 | 04:54 PM
You want to heat the area around the threaded plug, not the plug itself. You want the head to expand from the heat, causing the diameter of the hole to expand. If you heat the threaded plug, it will expand, and simply get tighter in the hole.
Old May 13, 2014 | 01:33 PM
turnUP's Avatar
ok thanks, I was heating it all. Im using one of those blue propane torches and im just paranoid since its the heads and ive never used heat to get something out.
Old Jun 27, 2014 | 04:50 PM
turnUP's Avatar
I took them to American cylinder inc. picked them up later that day, $ 25. Weeks ago just wanted to let yall know.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
squarehead
Nov 21, 2014 08:02 PM
JSK333
Sep 9, 2002 10:33 PM
