Blinkiing Lights
Old Feb 28, 2004 | 10:15 PM
BLDun's Avatar
Blinkiing Lights
At night my headlights and instrument panel on my 94 Z blink ever so slightyly. They never go completely out, just sort of strobe. I had the alternator checked and the battery. Said both were OK. I changed batteries but didn't help. Any suggestions???
Old Feb 28, 2004 | 10:17 PM
Jeremy_30th's Avatar
DOES IT HAPPEN WHEN YOU HIT BUMPS IN THE ROAD? MAYBE LOOSE WIRING
Old Feb 28, 2004 | 10:19 PM
BLDun's Avatar
No it happens all the time. Even if your sitting at a light. It is very slight and probably not even noticable to someone I'm behind but I can see it on the instrument panel and even my wife sees it. When I pull in the garage you can watch the head lights doing it. Got me baffeled!!
Old Feb 28, 2004 | 10:22 PM
GreenDemon's Avatar
I would hook up a multimeter and test voltage at the alternator- my bet is that your voltage regulator could be bad. Or your battery could have gone crazy- I had one that went from crap to full power when you banged on it. Or something in your car is sucking down some power. Shouldn't be too hard.
Old Feb 28, 2004 | 11:03 PM
LOW TRAC's Avatar
You don't happen to have a huge system in the back do you?
Old Feb 28, 2004 | 11:22 PM
Lower's Avatar
Watch the volt gauge when your car goes through a radiator fan cycling. Do the volts dip?
If so, hurry and find out the trouble. I've been stumped on this same issue for months.
Old Feb 29, 2004 | 06:12 AM
BLDun's Avatar
Stereo system is stock and I don't see any dip in the meter when the fan cycles. This is a constant strobe type effect regardless of what's running. I may do it all the time but I only see it at night when the lights are on. By the way, where is the voltage regulator located on the 94Z???
Old Feb 29, 2004 | 08:51 AM
Brent94Z's Avatar
Super Moderator
The voltage regulator is built into the alternator.
Old Feb 29, 2004 | 12:53 PM
BLDun's Avatar
That's what I thought. I had the people at Advance Auto do a check on it and they said it checked out OK. BUT it was a lady that did it so I'm not sure she knew what she was doing. I'll have to do one myself or take it a real mechanic.
dluna333
15
Mar 13, 2015 12:30 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
