Blew up a Z28..now trying to fix it.
Old Nov 28, 2005 | 07:18 PM
Nocturn's Avatar
Well long story short I blew up my brothers 97 Z28. During a powershift it blew something and started smoking out the exhaust. Took it to a place and they said it was hydrolocked. Anyways its been about 3 months and I just started taking it apart to fix it. I figure eitherway its going to need to be torn down just to know what were working with.
So today I took off the intake and throttlebody, but I noticed that when I first opened the throttle body there were little bits of metal chunks right behind the blades. I figure this can't be good...but what exactly can they be from? Im assuming not part of a rod because it would have to fly up past the piston and through the head to get to the throttle body. So if anyone has any ideas let me know. Im going to try and start removal of the intake manifold on Wednesday and see where that takes me...is there anything I need to watch out for, or keep in mind. I'v already looked at some of the guides people have on the net and they kind just blow over the intake manifold.
Also any guesses as to the damage is welcome. I figure best case scenario a blown head gasket and nothing more, drain coolant from cylinders and replace gasket good as new...but im thinking it will be a little more than that. The previous owner had a reputation for beating the hell out of the car and had N20 on it.
Old Nov 28, 2005 | 07:28 PM
1racerdude's Avatar
Re: Blew up a Z28..now trying to fix it.
Ya destroyed a piston. Just hope that it didn't transfer metal to both head and cyl and ruin the whole thing.
Old Nov 28, 2005 | 08:06 PM
Nocturn's Avatar
think the block is still salvagable? Or is it something you can't tell untill the heads are off?
Old Nov 28, 2005 | 08:29 PM
1racerdude's Avatar
Hard to say until ya see it.
Old Nov 28, 2005 | 09:51 PM
OBE1 95Z28's Avatar
Should be pretty ease to tell if you blew a piston once you pull the heads. Does the car have a stock TB? If the previous owner installed a 58mm TB, he could have shaved the intake TB ports and left shavings inside.
Old Nov 29, 2005 | 02:26 AM
Nocturn's Avatar
nope stock, and its rather big chunks, like the size of an eraser head.
Old Nov 29, 2005 | 02:42 AM
1racerdude's Avatar
What it probably did is drop a valve,busted the piston and the metal got in the intake through the intake hole with no valve. Then the metal in the intake get's sucked into ALL the other cyls and f***'s them up. Last one I did like that the block was cracked and both heads were junk.
Old Nov 29, 2005 | 03:07 AM
Nocturn's Avatar
lol your not making me feel better. Why would it drop a valve though?
Old Nov 29, 2005 | 03:12 AM
1racerdude's Avatar
They have a retainer or keeper failure. Especially if it had LT4 springs with stock retainers. Could have been RPM related.
There are several reasons.
Tear it down and see.But that's the only way the metal got in the intake.
Old Nov 29, 2005 | 06:03 PM
Nocturn's Avatar
Bit of an update, found alot more debris in the intake manifold. Do I need to drain the coolant to take off the intake manifold?
Old Nov 29, 2005 | 06:12 PM
1racerdude's Avatar
If ya don't want a big mess.
Old Nov 29, 2005 | 06:36 PM
jasons93z's Avatar
Is this really a problem? I have lt4 springs with stock retainers and ive been fine for about 10k miles.
Old Nov 29, 2005 | 06:45 PM
1racerdude's Avatar
Cost me an engine @6000RPM's. Destroyed the whole engine except the crank. The retainer folded up and looked like a cup what hadn't broke off.
Old Nov 29, 2005 | 06:46 PM
jasons93z's Avatar
well, i guess i will change those out when i have the top-end of the engine apart, because i definatly can't afford a new engine right now.
Old Nov 29, 2005 | 06:55 PM
ChickenScreamer94's Avatar
Someones has never taken the IM off before
No need to drain for taking the IM off, but you might as well since you will be pulling the motor anyhow.
