Bleeding Coolant w/o two bleed screws.
Old Aug 2, 2005 | 11:27 AM
Red95Formula's Avatar
Ok I was just sitting around lastnight thinking about how to bleed the coolant with out the two bleed ports. I removed the heater core and will not be running the lines that have the ports. So my question is how do you bleed it once these lines are removed? If anyone is wondering why I did this the car is pretty much going to be a track car only so I removed everything I wouldnt need.
Old Aug 2, 2005 | 11:51 AM
CheshireCat's Avatar
Re: Bleeding Coolant w/o two bleed screws.
Don't you still have the bleed screw on the neck of the thermostat housing?
If not, the only other place I can think of to bleed the system would be at the radiator filler... maybe park on a steep incline and let the air work its way to the top...
I'm sure somebody will have a better plan...
Old Aug 2, 2005 | 02:58 PM
flatlander757's Avatar
just let it run with the radiator cap off and little bubbles will come up as it gets the air out.
Old Aug 2, 2005 | 03:09 PM
30696bird's Avatar
Do you still have the heater core?? I need one. I have never done it anyway but the bleeder screws
Old Aug 2, 2005 | 03:10 PM
white/blackss's Avatar
umm that wont work on these cars.
i dont know what you can do, sorry
Old Aug 2, 2005 | 03:20 PM
30696bird---yes i still have the heater core if you need it email me. cbutler3@sc.rr.com
I still have a while before the motor is running but I was just thinking about it lastnight.
Thanks for the replies
Old Aug 2, 2005 | 03:31 PM
JBird33's Avatar
Why not? You could very well be right, but I wanna know why.
Old Aug 3, 2005 | 12:00 AM
revtime's Avatar
The one bleeder screw will work fine.
The other one was to bleed air out of the heater hose lines and since you don,t have them anymore the thermostat one will work fine.
I just did the same thing and many run the LT1 without the HVAC so its not a big deal.
Old Aug 3, 2005 | 10:44 AM
Ok thanks! I could not remember what two lines the bleed screws were on. I have had the car torn apart now for about 5 months.
Old Aug 3, 2005 | 11:17 AM
jsetzer's Avatar
You could eventually bleed it well enough that it would be safe to drive, but would be near impossible to get all the air out. 1 screw is plenty.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
1bad427ls1
Sep 23, 2015 01:12 AM
Bigtoyz97
Sep 21, 2015 01:44 PM
