Bleeding Brakes???
Old Jul 2, 2003 | 11:39 PM
InjectedSS's Avatar
Bleeding Brakes???
can you do it with the car off? or does it have to be on??
Old Jul 2, 2003 | 11:48 PM
1msfyter's Avatar
Bleed the ABS first(both nipples) then do the farthest from the brake booster. Then do it all over again.
Old Jul 3, 2003 | 12:19 AM
InjectedSS's Avatar
damn smokey i know that i need to know wether you have to bleed them with the car on or off?? also the ABS module? that with the car on or off??
Old Jul 3, 2003 | 12:48 AM
LPEdave's Avatar
Engine off
Old Jul 3, 2003 | 01:13 AM
1msfyter's Avatar
Stuff rags around the ABS unit it gets messy. Esp if you have an nice intake or so.
Old Jul 3, 2003 | 09:16 AM
jwade95Z's Avatar
I just bled my brakes, but couldn't figure out where the nipples on the ABS unit were ... any help? Top, Bottom, Side? I didn't see anything that looked like a bleeder screw.
Thanks!
Old Jul 3, 2003 | 06:31 PM
InjectedSS's Avatar
Thanks!
their right there in front of the ABS unit! you will prolly have to remove your intake to see them
Formula Steve
Sep 19, 2023 08:31 AM
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
1bad427ls1
Sep 23, 2015 01:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
