Bilstein BTS Suspension system.
Old Aug 15, 2003 | 11:18 PM
Cmr0z28's Avatar
Is the Bilstein BTS Suspension system worth the money? www.shox.com has it for $569
"BTS system with Bilstein shocks and springs set of 4. Lowers 30mm front and rear $569.00"
would my car handle and corner better with KYB gas-a-just shocks and BMR 1" lowering springs?
let me know what you guys think.....I don't want to spend too much on a springs/shocks setup. i think around 600 is my limit.
Old Aug 15, 2003 | 11:40 PM
zlightning's Avatar
Well what do you want your car setup for? Auto cross? Just daily driving? I am sure others will ask more questions it just seems like those are the two main questions.
Old Aug 15, 2003 | 11:43 PM
Cmr0z28's Avatar
i will be at the drag strip every here and there but autoX is so fun.....i want my car to handle the best possible around corners and stuff. i put a BMR shock tower brace and polyurethane sway bar bushings and end links today and it made a huge difference....now i gotta get my SFCs welded on then i wanna do shocks/springs
Old Aug 16, 2003 | 12:29 AM
zjet's Avatar
the bilstien kits is the same hd shocks as sold of the shelf with lowering springs.i used the hd with eibach pro - kit from shox myself it was 50-75 cheaper than the eibach kit.you will love them. it corners on a rail.handles almost as well as my buddys zo6
Old Aug 16, 2003 | 02:03 PM
Cmr0z28's Avatar
thanks to atljar, i know where to get the bilstein shocks for $285 for all four. instead of spending all the money on the bilstein shocks/springs package i think i may want to just get the bilstein shocks and BMR or eibach pro kit springs. does anyone know which are stiffer and which will handle better? BMR's lower 1 inch.
Old Aug 16, 2003 | 03:44 PM
Cmr0z28's Avatar
anyone?
Old Aug 16, 2003 | 05:31 PM
Cmr0z28's Avatar
jeremy did you need to have your bilsteins revalved?
Old Aug 16, 2003 | 07:19 PM
Cmr0z28's Avatar
Old Aug 16, 2003 | 10:29 PM
car_ramrod's Avatar
most people who get bilsteins have only the fronts revalved. As far as that goes I'd talk to the guys at www.stranoparts.com its pretty much a one stop shop for F-Body suspension stuff and they really know their stuff. You can get the revalved shocks straight from them instead of buying them from a different place and sending them the shocks and then paying to get them back too They have excellent customer service and will help you pick out the perfect suspension for your needs. hope this helps
CR
Old Aug 16, 2003 | 11:36 PM
Cmr0z28's Avatar
thanks ramrod chowder
Old Aug 17, 2003 | 03:57 PM
zjet's Avatar
no.havent revalved them i have had no problems with them.
Old Aug 17, 2003 | 10:01 PM
stereomandan's Avatar
I put Bilstein HD's on all four corners yesterday with a toally stock suspension. I love them. I didn't revalve them, and kept the stock springs. Personally, I don't think I would want much stiffer of a spring. The Bilsteins work great with my stock suspension.
Dan
Aaront810
Aug 29, 2020 09:34 PM
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
KYWes
Aug 10, 2015 07:03 PM
force10
Jul 30, 2015 04:56 PM
