Biggest Cam on Stock Converter.
I've been away from the Fbody scene for awhile so I'm a bit rusty on some of the new stuff for the LT1's in the last few years. I've got a little bit of money saved up and would like to do a cam swap. I'm wondering whats the biggest cam I can run on the stock TC? Thanks.
Re: Biggest Cam on Stock Converter.
Personally, I wouldn't run anything bigger than the stock cam on the stock converter. But that's not to say you can't run something along the lines of the LT4 hotcam or equivalent. IMO, a high converter on the stock cam provides more overall gain than an aftermarket cam with a stock converter.
With 3.73 gears you should be able to run any (stage 1,entry level) whatever
you want to call it.Just keep the intake duration around 216-222 and the LSA
at 112 and it should work fine.And you can always add a stall later.
I admit the Granatelli MAF was a bad investment, but it was the first "mod" I did to the car 11 years ago when I bought it. But the junk pulleys are staying. lol
Looks like I'll wait to do the cam swap until I have a stall ready to go in too. I've narrowed my choices down to the CC503 or the GM846. Any opinions on either of these or something else close to them? Thanks again.
I am partial to the AI 226/234. Lots of guys are flying with that grind on stock heads.
I dropped .5 and gained 6mph with the crane 227 cam and 3.73's with the stock converter. Definitely wasn't a waste. It had 0 driveability issues and still launched harder than the stock cam.
With my first heads/cam setup I had the AI 190cc heads and the 226/234 cam and the car went 11.9 with 3.73s and a 3400stall, that cam was mellow enough for pretty much anyone to like it.
