biggest cam for ported heads
Old Mar 21, 2009 | 02:06 PM
cory123456's Avatar
im about to rebuild my motor leave it a 350 still and port and polish the heads and get all new valvetrain for it whats the biggest cam for ported heads i can get?
Old Mar 21, 2009 | 09:11 PM
sn8ke eatr's Avatar
gm847
Old Mar 21, 2009 | 09:30 PM
RamAir95TA's Avatar
Bigger is not always better. Get that out of your head now.
Originally Posted by sn8ke eatr
gm847
No. Depends SOLELY on how your heads flow, at both peak and mid-lift. The more correct response to the OPs question is a custom grind. Send your ported head flow numbers to AI or LE, and have them grind you something. Sure an off-the-shelf cam will work, but they are designed with a wide range of applications utilizing older camshaft technology.
Old Mar 21, 2009 | 09:37 PM
87bandit's Avatar
like joe said bigger is not always better especially with a stock RA
no point in having a cam that peaks at XXXXrpm when you're RA's safe rev point is below that. also average power > peak power
do what joe said, get some flow numbers and head to either Lloyd Elliott (www.elliottportworks.com) or Advance Inductions (www.advancedinduction.com)
Old Mar 22, 2009 | 10:14 AM
cory123456's Avatar
ok thanks ill get the flow numbers then go from there
Old Mar 22, 2009 | 02:49 PM
gatorhead's Avatar
I seen peak and mid lift numbers mentioned, and yet as always low lift is left out of the picture. Low lift is where it begins and is always the last thing looked at especially when bench racing. I tend to go against the grain here and figure in little things like TORQUE, which you actually drive and what is responsible for getting your car out of the hole at "low lift".
You said you are leaving your car a 350 stock cubic incher, so what are you doing to the bottom end? Are you replacing any of the components or are you simply going to re-ring it and throw some new bearings at her? At a minimum I would replace the rod bolts as they are the weak link in a stcok bottom end, that will give you a little added insurance when you want to play with it.
Also what are the goals for your car. It doesn't sound like an all out race vehicle to me, is it going to be driven often?
Old Mar 22, 2009 | 09:24 PM
87bandit's Avatar
as gator said rod bolts are the first weak link in the RA, under high rpm they have been known to stretch, such a thing will limit your safe revving point and limit your cam choices
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
pimpss96
Feb 12, 2015 01:28 PM
jmzlt1
Mar 13, 2003 07:26 AM
