Bigger throttle body??
Old Apr 12, 2007 | 07:44 PM
ChevyTuffD.A.'s Avatar
Would I benefit from getting a bigger throttle body? Mods in signatue. If so, what brand/size would u recommend? Cost does matter. Thanks. Dustin.
Old Apr 12, 2007 | 08:22 PM
Severous01's Avatar
yes
stock rebuilt with port.
ebay is the easiest place to get it, and you can get it powder coated whatever color you want for an extra like 20 bucks.
or, AS&M 58mm if you want more than about 54mm
Old Apr 12, 2007 | 08:42 PM
I looked on ebay right after i posted this thread. Those ported stockers like pretty good to me. Isnt the intake only bored to 52mm??
Old Apr 12, 2007 | 10:42 PM
zlighting's Avatar
Ditto, stock TB ported to 52mm w/ custom matched airfoil, or keep it stock with an air foil.
Old Apr 14, 2007 | 05:02 PM
RedsTA's Avatar
A local guy dyno tested all different sizes of TB's and showed about a 10rwhp/15tq gain with a 58mm tb. Id go 58 instead of wasting money on everything else.
Old Apr 14, 2007 | 11:11 PM
Z-RATED94's Avatar
But the question is, what kind of mods did the engine have, how many ci and how much hp was the engine making? With out this info your post is useless.
Old Apr 15, 2007 | 03:58 AM
neversummer's Avatar
I dunno. I go back and forth on this. I should hit the dyno to prove to myself, but the SOTP feel says that car is faster/more responsive with BBK 58mm than with stock TB. I've swapped back and forth like 5 times. I have minimal mods - 355, hooker shorties, no cat, air, egr,
Old Apr 15, 2007 | 07:28 AM
96capricemgr's Avatar
With a 58mm throttle response is signifigantly changed and most people will mistake this for more power. What is actually hapening is the engine gets more air with 58mm blades at 10degrees than it did the 48mm at 10 degrees so it is like you are opening the throttle further.
On a stockish motor rebored stocker to 52mm is the way to go. If you are going to buy a new TB then it only makes sense to skip right to the 58mm with appropriate intake opening porting.
Either way get the pcm reprogrammed if you have a A4.
Potent77
Mar 16, 2022 12:13 AM
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
warmeck
May 1, 2015 11:30 AM
QuickSilver02
Apr 7, 2015 11:12 AM
