bigger cam than a 306?
I have a CC306 in my car now and I am putting in a 383 stroker with a set of Ported Lloyd Elliot Heads that were fixed by JDS Induction Products. I want a bigger cam than a cc306 But I dont want to go solid roller. The springs I have are good to .600 lift Changing springs isnt really a problem but I Dont want to have a Issue of valve to Piston clearence. What is a bigger cam than a 306 but small enough not have have problems?
Matt
Matt
Re: bigger cam than a 306?
I have the GM 847 and I like it, just wish it had more overlap.
This baby pulls all the way up to 7000 rpms, so there would be no need for me to get a more duration cam. The PCM stops at 7000. The lift will put you right up to .600 lift with 1.6 rockers, so this may fit you like a glove.
Of course, everyone is going to tell you to get a custom grind. When they do, ask them for some specs and watch how everything gets silent.
Just my .02
D Moss
Just my .02
D Moss
I have a custom grind best way to go about picking one is call comp and tell them what you want to do with it. mine did have clearance problems between the retainer and the seal so i had to go with longer rods and valves
JasonD
Jul 27, 2002 08:57 PM
