Big Injectors and passing smog ?
Old Jan 14, 2005 | 10:56 PM
RCF925's Avatar
I'm running the Siemans 72# injectors with the Acceleronics Box and just flunked my Smog Pre-test in Ca. All you running Low Z injectors have any problems passing smog due to the big injectors? Or should I say any of you with the big injectors think they are causing you to run rich at idle. My car is running real fat at idle and a little fat in the 2500 rpm test. i'm also not getting the EGR to work at all which may be cam related but I doubt it cause I've passed before with similar cam. I'll be checking for vacuum leaks tommorrow. Any thoughts would be appreciated.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
gomaro
Events and Cruise Spots
May 6, 2015 09:02 AM
cheapchevy
Apr 8, 2015 08:48 PM
edman
Mar 13, 2015 09:39 PM
siguy
Nov 27, 2014 10:07 AM
