big heads and small cam
Old Nov 27, 2005 | 06:14 PM
DavesLT1's Avatar
I was wonering if going with hogged out heads like the LE3's and putting in a smaller cam to pass emissions would still give gains. The cam I was thinking was either a CC305 or 503. anyone know what would happen?
Old Nov 27, 2005 | 06:19 PM
Beast96Z's Avatar
Re: big heads and small cam
My guess would be a signifigant loss in TQ in the low to mid range area and then when the heads want to shine up top, you would run out of camshaft. It'd probablly do ok from 4500-6500 though.
Old Nov 27, 2005 | 06:49 PM
96flame's Avatar
Likely the LE1 heads would suffice for what you want to do. Best to ask Lloyd directly and he'll set you up with what you want. First thing he's gonna ask is what are your goals i.e. HP and ET's or just driveability.
Old Nov 27, 2005 | 07:58 PM
vin1382's Avatar
I have the 503 cam, and Lloyd had recommended to me his LE1 heads. I dont think the cc305 or 503 make much power past 6200 - 6300 rpms..and id expect LE3 heads to make power way over that. I'd agree with the poster above that you would probably lose some low-end..and then not have enough RPM with the cam to make up the power using gearing.
Old Nov 27, 2005 | 08:31 PM
turbo_Z's Avatar
It lot rather run LE3 heads with that cam than LE1 if you ask me. People get too complicated with crap on this board anymore. You want the best flowing head possible to make the most power.
Old Nov 27, 2005 | 08:34 PM
Admiral94's Avatar
With either one of those cams I'd go with the LE2 heads. Better components than the LE1 heads and will still work with the milder cams and RPM.
Old Nov 27, 2005 | 10:14 PM
1racerdude's Avatar
Get the lift right for your flow and it will gain a bunch
Big heads=smaller cam=same HP as reversed.
Old Nov 27, 2005 | 10:22 PM
my94blackz's Avatar
WORD!!
Old Nov 27, 2005 | 11:39 PM
RedLT4Mike's Avatar
Do a custom grind with lets say.....
.590 lift on both sides
very little overlap
with duration something like 21x, 22x.
Old Nov 28, 2005 | 04:45 AM
hvyss's Avatar
Read my sig. I am running the LE2 heads and comp 503 in a 96 Impala SS. Car runs low 12's all day long.
HVY SS
Old Nov 28, 2005 | 05:11 PM
engineermike's Avatar
Agree 100%. Port volume isn't nearly as critical in low-end torque production as most people think. You could put AFR 227's on there and not lose more than 10 ft-lb down low. I had an 8.5/1, 350 cid motor with AFR 210's, the GM 847 cam, and a Victor Jr intake. Sound like it would be a pig down low? Nope, it had very decent low-end torque and ran pretty good too. 11.96 at 114.5 on 87 octane.
Old Nov 28, 2005 | 05:54 PM
hsyr's Avatar
Take a look at the LS7. Big heads, little cam and lots of power! I don't think GM wanted a 4000+ rpm engine with no bottom end
Old Nov 29, 2005 | 07:23 AM
CANTONRACER's Avatar
There are some guys floating around with cams that most would balk at running damn good....small cams can make very good power.
Old Nov 29, 2005 | 02:10 PM
LT4POWR's Avatar
not that mine's "small" or even emissions legal, but it certainly isn't "large" compared to many others around here. DavesLT1 - Why not just get some LE2 heads and a custom smog legal cam from LE?
Old Nov 29, 2005 | 02:52 PM
Mindgame's Avatar
I've had a lot of fun with "great" heads and small cam.
I've won alot of races and even a little money with "great" heads and big cam.
All in all, I prefer to have the "right" heads for the combination.
-Mindgame
