Better Lighting ?
Old Jul 10, 2003 | 11:48 PM
Van5150's Avatar
Better Lighting ?
I know my headlights suck, they dont throw out as much light as I know I need. Besides the $700 PITA conversion has anyone made any improvements to them ?
Almost makes me think the front end swap off of a LS1 camaro would be worth it.
Old Jul 11, 2003 | 12:04 AM
ibanez6rg's Avatar
Hella FF75s, check the appearance section for threads on them.
Old Jul 11, 2003 | 03:41 AM
revtime's Avatar
You know sometimes what the ricers do is a good thing.
I put in some of them bright white bulbs in my headlight housing.
Yes you have to do some modification to put these in but it is worth it. The old ones are sealed with some white gunk but I use clear silicone to seal the new bulbs into the housing and let them sit overnite.
Big difference.
Cheaper too.
Old Jul 11, 2003 | 03:50 AM
pu12en12g's Avatar
Cheapest Way:
- 130w bulbs siliconed into the stock housings.
($14 a pair)
- High wattage wiring harness
(About $25)
I did a full set for a friend of mine tonight.. it took less than 30 minutes
dluna333
15
Mar 13, 2015 12:30 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
