best year lt1 to mod?
Old Aug 10, 2004 | 10:44 AM
RiceKillerZ28's Avatar
finally sold my car today and still looking for a z28 m6 to buy...what year is the best one to mod, if it even matters. thanks.
Old Aug 10, 2004 | 11:17 AM
Bawls's Avatar
Re: best year lt1 to mod?
What are you looking to spend? Do LS1's still cost loads more to mod then the LT1s. I know they did when I had my LT1. LT1s (93-94) single cat, obd1. 95+ Dual cats obd2. 1993 LT1 = speed density (no MAF).
I'd say 93 or 94. Now if you're talking LT1 vs. LS1...
Old Aug 10, 2004 | 11:19 AM
WS Sick's Avatar
Only about 10 percent of the 95s are dual cat cars, I'd vote for an OBD 1 95.
Old Aug 10, 2004 | 11:20 AM
Bow94z's Avatar
well, seems like most people llike the 95 as the best year.
Single cat Car, Still Obd-1, and has the vented opti.
i drive a 94 and would rather have a 95 IMO....
Old Aug 10, 2004 | 11:26 AM
Bawls's Avatar
Oh yeah. Sorry about that. Now its coming back to me, lol I wanted a vented opti too back when I was under mine replacing it for the 2nd time.
Old Aug 10, 2004 | 11:34 AM
Red96Lt1's Avatar
Exactly. Do not buy a 93. They are speed density and are different that all the others. Usually 93 parts only fit 93 cars. Don't know why someone said 93.
Old Aug 10, 2004 | 11:36 AM
Bawls's Avatar
Sorry if it seemed like I was listing the 93 as one of the best years to mod. I wasnt I was just listing off what had what so he could make his decision.
Old Aug 10, 2004 | 11:41 AM
orbitalshock2k's Avatar
I got the OBD1 95' pretty good car. 96-97s come with 10 more HP though.
Old Aug 10, 2004 | 11:56 AM
Red96Lt1's Avatar
True, they come with 10 more HP, but that's because they are dual cat cars. Which is insignificant if you are planning on modding it anyway. (ie. Headders).
You can usually tweak about 10 more HP out of an OBD I tune because it's a less intrusive diagnostic system.
Old Aug 10, 2004 | 12:11 PM
GreenDemon's Avatar
Just look for the best deal you can, every year is slightly different, but not enough to say "buy this year". Just remember that the later models will probably be more reliable, and the earlier models will be easier to tune.
That said, I always vote for 95 (vented opti + obd1) or 97 (new interior).
Old Aug 10, 2004 | 12:29 PM
RobsWS6's Avatar
I'd say 95-97 as they are pretty much the same. I think the cam changed a little in 96. The OBDII computer is easily swapped for a OBDI. I did that in my 96 WS6 after the cam change since nobody had started programming OBDII back then. Better coil and wires in the OBDII cars also.
Old Aug 10, 2004 | 02:21 PM
1995CamaroZ28's Avatar
1995 Camaro Z28
Old Aug 10, 2004 | 02:45 PM
Javier97Z28's Avatar
Moderator
I'd probably buy either a 95 or (I'm biased) a 97.
97 has the newer interior which IMO looks better than 96 and below (I had a 96 before also).
both 95 and 97 will have the vented opti advantage as well.
the whole OBD2 thing really isn't that big a deal, just programming it is more expensive.
Old Aug 10, 2004 | 03:21 PM
ARRFormula's Avatar
I would say the '94/'95 and the '96/'97 LT1's both have some positives and negatives.
I would think you'd want something like an OBD1 computer with the OBDII vented opti/timing set. That would be a good set to start with.
Old Aug 10, 2004 | 03:36 PM
besz28's Avatar
iam pretty positive it is the 1994,also heard they run the strongest and make the most power. and that black ones are 10 more hp
