Best Way To Weld In Sub Frame Con.
Old Mar 1, 2004 | 02:00 AM
  #46
Xride's Avatar
for the "challenged" people
http://www.speedinc.ca/redss/ramp.jpg
What I think you did
http://www.speedinc.ca/redss/rampass.jpg
Old Mar 1, 2004 | 02:05 AM
  #47
ucantZme's Avatar
you didnt say lay it flat on the ground until i said something about it, you simply said lay it flat. which i took as lay it flat up on the ramp. and it still wouldnt work, i tried. and as far as the "how to", are you sure about that cojack?!
Old Mar 1, 2004 | 02:09 AM
  #48
Xride's Avatar
Originally posted by krispy
if ramps are too big try putting slates of wood in front so those lift ur front end before u get to the ramp
and you tried like that... with your stock hieght car... and you couldnt?
Old Mar 1, 2004 | 02:13 AM
  #49
ucantZme's Avatar
well i miss read what krispy had said, and YES, for the second or third time. i tried that, it did not work. ramps were too tall. and yes stock height car, you couldnt have gotten onto the ramps in YOUR car either. if need be i will measure the ramps for you.
Old Mar 1, 2004 | 02:15 AM
  #50
Xride's Avatar
How tall are they?
I bought the tallest ones I could get, and my SS can up with a 2x4 easy, ramp couild be a bit taller, or less long and I could still make it up.
Old Mar 1, 2004 | 02:16 AM
  #51
ucantZme's Avatar
good god man, just to shut you up, as if that would work. ill measure them right now.
Old Mar 1, 2004 | 02:20 AM
  #52
ucantZme's Avatar
they are exactly 16.125 inches tall. still think i, or much less YOU can drive up on them with a 2X4?? i dont.
Old Mar 1, 2004 | 02:26 AM
  #53
Xride's Avatar
damn, thats 6" taller then mine.
where you get them? I want a pair, should make headers that much easier.
Old Mar 1, 2004 | 02:30 AM
  #54
TobyZ28's Avatar
OMFG This is the funniest post EVER!!!
Old Mar 1, 2004 | 02:33 AM
  #55
InjectedSS's Avatar
That's what Im talking about
Old Mar 1, 2004 | 02:38 AM
  #56
ucantZme's Avatar
i got them from a gm dealership where i used to work. they were cleaning out abunch of their old **** so i got them and took em home.
Old Mar 1, 2004 | 02:44 AM
  #57
TobyZ28's Avatar
Get 3x 2x8/10's.
Bottom ones say 5'. Next ones 3', Last ones 1'
Line one end up. Toss a few nails in it (none too close to the ends though).
Cut the ends eqal to the slop of your ramps.
Lay em down on the ramps and roll it up carefully
If you wanna really make them nice u can taper the "steps" with cuts too just for a nicer ride up them
Old Mar 1, 2004 | 02:46 AM
  #58
ucantZme's Avatar
Get 3x 2x8/10's.
i may have considered doing that b4 i found out about the little curb deal. but i dont even have the car anymore, i gta Z71, so who needs ramps anymore.
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
4586
Aug 22, 2015 01:09 AM
4586
Aug 18, 2015 07:08 AM
