Best way to track down a misfire??
Old Apr 28, 2005 | 12:38 AM
Black1995Z's Avatar
Angry Best way to track down a misfire??
I have a pesky misfire. I replaced the fuel filter, opti, coil, plugs and wires and still cant get rid of it. I must've done something wrong or burned a wire. I did get rid of it for a few weeks when I installed my TR6s for my N2o setup. BUT its back!!!
Can someone help me out? Any tips to finding out the problem? I did notice a smell today when it started misfiring again. It was the smell similar to that of burning wood... unlike anything ive ever smelled.
Also, I recently installed TR6s... what do fouled plugs look like?
Thanks guys, tips, tips, tips!
Thank you
Old Apr 28, 2005 | 02:49 AM
onecrazygm's Avatar
Re: Best way to track down a misfire??
try look in teh engine compart with no lights on at night... around the headers , spark plug wires and what not... if taht dont help try to make sure no wires are burnt and if there all the way on... if not might be a opti problem...
Old Apr 28, 2005 | 01:05 PM
TobyZ28's Avatar
Just want to add to the above comment, it has to be REALLY dark. It being dark outside with streetlights neearby or lights from houses is not dark enough. Best thing to do is use a garage at night with all the lights off..
Old Apr 28, 2005 | 11:51 PM
whitehooptie's Avatar
Pull plug wires off while it is running. The one that has no change is your problem.
Old Apr 28, 2005 | 11:55 PM
Black1995Z's Avatar
yes, excellent idea!
thanks guys! ill try tomorrow!
Old Apr 28, 2005 | 11:59 PM
markinkc69z's Avatar
You might get a spray bottle and put it on stream and spray each header tube. If you have a dead cylinder at idle the water will just sit there and sizzle.
Old Apr 29, 2005 | 12:01 AM
Another good idea. Only works if you have headers though. I do it the lazy way and spit on them.
Old Apr 30, 2005 | 06:04 AM
slopokrodrigez's Avatar
You're never gona pull wires off with a stock manifold when it's running. Anyone that suggests it, never did it. I wouldn't even attempt it with headers. But then I could use my infrared thermometer to find a dead hole. Doubt you have a dead hole. If you think it's an ignition misfire, use a timing light to find it. That is, assuming it's ocassionally misfiring.
You said you have a misfire. What makes you say that? Does it idle rough? Do you feel anything when you are at speed?
I also noticed a few things in your signature. One is you have no screen in your MAF. Bad idea. Removing it gains nothing but can add to turbulence in the incoming air in turn making in-accurate metering of the incoming air. Add to that, your free ram air set up that may have a cotton filter that got over oiled and "here's your sign".
The other thing I noticed is you have not cats but did not notice you removed the EGR. The EGR valve is closed with exhaust back pressure when it's supposed to close. If you uncork the exhaust, the EGR may not be fully closing.
Just a few ideas to consider.
Old Apr 30, 2005 | 01:01 PM
And maybe the person that has suggested it has done it. Both manifolds and headers.
Old Apr 30, 2005 | 03:25 PM
moparman's Avatar
You could unplug them from the opti.
Old May 1, 2005 | 11:01 PM
PGM95Z's Avatar
I would definitely put the screen back in the MAF, but GENTLY clean the MAF wires first with spray electronics cleaner, or you can try alcohol on qtips (be gentle tho!). The reason for this is because oil from your filter can slowly build on the wires.. Also make sure that you have absolutley no air leaks after your MAF, which would cause unmetered air. I would also check your IAT to make sure that is working correctly. And the EGR as slopok said. Shoebox has some good instructions on how to check your sensors and such...
94ZinEdgewater
Sep 8, 2015 09:55 PM
Louey
Pacific
Sep 1, 2015 07:19 PM
Louey
Pacific
Aug 25, 2015 01:53 AM
Louey
Pacific
Aug 7, 2015 01:47 AM
Louey
Pacific
Jul 27, 2015 09:58 PM
