The best way to reach spark plug & wires and replace???
Old Apr 9, 2006 | 01:40 PM
DIYAR21's Avatar
how??
l really need some infor about this. l have been thinking.. how the hell am l gonna reach and replace those? also am l gonna twist the spark plugs or just force and pull them?
thanks
Erdal
Old Apr 9, 2006 | 03:20 PM
2000GTP's Avatar
Re: The best way to reach spark plug & wires and replace???
Originally Posted by DIYAR21
how??
thanks
Erdal
The spark plugs just dont pull or twist out, you need to take them off with a special spark plug socket and ratchet. There is no real easy way to do a plug/wire change on these cars. You will find it works best to pull some plugs from the top and others from the bottom of the car. Also, in order to get to plug #2, removal of the alternator will make it alot easier. As for the wires, they are pretty easy to do on the drivers side, the passenger side is trickier however. Just take your time routing them and make sure that the boot ends are firmly snapped onto the spark plugs and the Opti-spark terminals. That is all I can think of right now,also, if you do a "search", you'll pull up alot of good info. on this as well. Good luck.
Old Apr 9, 2006 | 03:24 PM
DIYAR21's Avatar
thanks man..
so l am gonna have to use a tool to pull them? man, there is no room even for my hands.. how am l gonna use tool over there? how much is the tool by the way and where can l find?
Old Apr 9, 2006 | 03:26 PM
2000GTP's Avatar
thanks man..
You are going to need a 5/8" spark plug socket and either an accompanying 3/8" ratchet or an open end wrench to slip over the hex shape of the socket. The socket should only cost a few bucks from any auto parts or hardware store.
Old Apr 9, 2006 | 03:32 PM
DIYAR21's Avatar
thanks man..
do u think l can do it?
l dont have knowledge about cars.. l replaced the radiator last week and l replaced power widnow motors and on toyota, starter. these are the only things that l have done on cars..
l am just scred to touch.. l dont wanna break the car down completely or damage the engine.. at least it is still running.. should l do it?
Old Apr 9, 2006 | 03:35 PM
2000GTP's Avatar
Well, you can look under your hood and get a feel for what you are up against. Its not a job that requires alot of technical know-how, but it is still difficult, hence the reason why alot of shops charge a good sum to do it. Do you have any friends/family that are good with cars? If so, maybe you can enlist their help as well.
Old Apr 9, 2006 | 03:54 PM
DIYAR21's Avatar
l have nobody in the USA. l am a newbie here.. by myself . it has been 8months.
if l am not gonna damage my engine, l would like to at least try.
man, could u please list of tools to me that this job requires?
someone told that l will need a speacial tool to remove the opti.. is that right? l thought maybe l was gonna unbolt the opti and pull it.
also it has to be GM origonal opti or can l buy from autozone?
also another question.. autozone sells distrubitor and distrubitor rotor and cap kit.. WTF?? which one shoudl l buy?
thanks
Old Apr 9, 2006 | 04:12 PM
eds96ragtop's Avatar
as far as the distributor or the cap and rotor if you have the $$ buy the whole thing. the whole distributor. it would be best to get the one from the dealer but it all depends on your $$ i did the opti and waterpump and plugs and wires all at the same time took 2 days but i did not spend all my time working on it. changing the plugs or just about anything is frustrating on these cars so give yourself time to be able to relax instead of pulling your hair out. i cant remember the spark plug socket size but you can find out by looking at the new ones youy buy while at the store they should be the same size as the old ones.
it is also a good idea to buy all the flexing attachmens for the sockets that you can they will help in the tight spots!
Old Apr 9, 2006 | 04:14 PM
also you can call jason cromer to get a discount on dealer parts. but you have to wait for shipping but you wilkl save cash just doi a search for jason cromer and you can find his number.
good luck
ed
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
mritter1965
Feb 9, 2015 07:01 PM
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
