Best Transmission fluid Cooler?
Old Nov 28, 2003 | 10:29 PM
stang_killa94's Avatar
I need a really good transmission fluid cooler. What is the best out there? Its for a daily driver 94 z28 A4
Old Nov 28, 2003 | 10:40 PM
Mr Kevlar's Avatar
The B&M should be ok, I also hear that the Hayden's are good too.
http://thunderracing.com/index.cfm?f...ategoryid=1100
Old Nov 28, 2003 | 11:14 PM
formula383's Avatar
I have the B&M in my car and it is the one I would recommend. Also installation is very easy. I got mine from Thunder Racing also.
Old Nov 28, 2003 | 11:22 PM
Cool thanks, this is probably the one im gonna end up getting......where did you place it?
Old Nov 28, 2003 | 11:23 PM
S.J.S.'s Avatar
I got a B&M Supercooler thats been good for me. Hottest it ever gets is like 180.
Old Nov 28, 2003 | 11:28 PM
ibanez6rg's Avatar
Where can you buy an install kit for these?
Old Nov 28, 2003 | 11:41 PM
FastZinTennessee's Avatar
If you get a B&M supercooler you shouldn't need an install kit. I got mine(24k lb gross vehicle weight cooler) from summit, and it had enough hose, clamps and zip ties to install. I even had a few items left over that I didn't need. I think I paid about $55 for the cooler.
Old Nov 28, 2003 | 11:42 PM
formula383's Avatar
Everything you need to install it come with it, it is a kit.
Old Nov 28, 2003 | 11:45 PM
Exactly where did you place it? My car is lowered and i want to know if i can put it up high enough so that i dont rip that thing off.
Old Nov 28, 2003 | 11:48 PM
formula383's Avatar
I put mine on the front of the radiator.
Old Nov 28, 2003 | 11:51 PM
ibanez6rg's Avatar
But I bought a cooler off another member!
Old Nov 28, 2003 | 11:52 PM
rskrause's Avatar
Moderator
I have the B&M "Hi-Tech" cooler. Due to the integral fan it is very compact and can be mounted almost anywhere. Mine is tucked up horizontally inder the passenger side headlamp and it works fine even with my loose converter and hi-po combo.
Rich Krause
Old Nov 28, 2003 | 11:54 PM
revtime's Avatar
If you buy the B&M supercooler you can install it and still have enough parts left over to do a throttle body bypass.
at least I did on my 94.
Old Nov 28, 2003 | 11:56 PM
AsianSensation's Avatar
I got the biggest tranny cooler that will probably fit a fbody per Brent Franker's recommendations, Hayden 1405, 26,000 lbs gvw.
Edit-I put mine's in front of the condensor. Dunno how you can put it in front of the radiator since the radiator is sandwich between the condensor and electric fans.
Old Nov 29, 2003 | 12:16 AM
formula383's Avatar
It is very easy to put it in front of the radiator. Plus the kit comes with like some almost like Zip Ties that you stick through the radiator and put a lock on the other side.
