best timing chain upgrade?
Old May 7, 2004 | 08:47 AM
CrAkD X 95TA's Avatar
im getting the hotcam kit installed gonna have the timing chain replaced too i was first looking at the heavy duty timing chain kit from GM but was wondering if there was a better kit.
Old May 7, 2004 | 09:26 AM
GREGG 97Z's Avatar
The LT4 extreme duty is about the best one you can get for an LT1. Another very good chain is the Cloyes double roller, it's about 1/3 the price but it requires eliminating the water pump drive and running an electric pump. That's what I went with.
Old May 7, 2004 | 09:30 AM
truedualws6's Avatar
I can't say if there is a better kit, but I have always
used genuine GM parts and never been disappointed.
Get the GM extreme duty set since it was designed
for the setup you are planning on running. Based on
your user name I am assuming that you have a "Gen II"
LT1.
Now that I have typed this out I see that you already
have the same response.
Old May 7, 2004 | 11:43 AM
MTL_Z28's Avatar
What about just getting a stock replacement?
Old May 7, 2004 | 06:01 PM
ChuckZ28's Avatar
another for the Cloyes double roller and electric WP conversion. Much cheaper and havent ever gone above 180 degrees under the hottest weather and lots of use of the gas pedal
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
