Best Timing Chain
Old Apr 27, 2006 | 01:18 AM
92_RSCamaro's Avatar
Best Timing Chain
I Sure its been asked but, I have a first gen LT1 1992 Corvette Block and Crank and want to know what the best timing chain set? Everying I've looked at is $360+ is there anything cheaper.
Old Apr 27, 2006 | 01:34 AM
Z95m6's Avatar
Re: Best Timing Chain
Unless you swap to the 95+ opti setup you are pretty much stuck with the stock chain. I believe Comp supposedly has a chain for 92-94 guys but i believe its about $500.
Old Apr 28, 2006 | 08:45 PM
Yea but I thought also what limits me from changing to a 95+ setup is the crank and gear that comes with it in the timing chain set. I'm doing a motor swap on a 3rd gen so going to newer opti wouldn't be hard but what about the crank gear issue?
Old Apr 28, 2006 | 08:53 PM
Dave89IROC's Avatar
huh?
Old Apr 30, 2006 | 12:59 AM
What im trying to say is are the camshaft/crankshaft sprockets the same on a 95+ timing chain kit and a 92-93. Also what all do i need to do to convert to 95+ opti setup? So basically it would be nice not to have to pay $500 for a damn timing chain. The block and crank or a '92 corvette
Old Apr 30, 2006 | 05:22 AM
Dave89IROC's Avatar
crank sprocket, if the chain is the same, its the same
cam sprocket is where the difference is, 92-94 has a same center hole, which is splined(opti drive), 95-97 has a large center hole(opti driven by a extended cam dowel)
there is a page with a list of parts needed to convert, but here is the jist of it
vented opti(95-97)
vented opti timing cover(95-97, 95 commonly perfered)
vented opti electrical harness($36 from casper)
vented opti vacumn harness
95-97 camshaft
95-97 timing set(a aftermarket double roller will work, if you run a ewp, and with some slight clearancing of the timing cover)
Old Apr 30, 2006 | 09:32 AM
lethal93ta's Avatar
do you plan on using the hole wiring harness off the vette? most people that do a swap go carbed and run a regualr Dis and dont need the opti up front, then you can put an electric water pump on there and run a true double roller, I swapped my opti to the vented set up and got an electric pump and put a cloyes double roller in there, the vented opti is a much better set up, all you need is opti itself, timing cover, wire harness, vaccum harness, and the timing chain, you best off going with a electric WP so you can run a true roller chain, there a lot better and have a lot less slack than the normal LT1 chain does, they make a over sized cam gear for it to take up the slack but those gears get expensive.
Old May 1, 2006 | 12:42 AM
I going to run a 95 computer and harness off a Z28. Also I have a LE2 Package that going on the car with the custom grind cam. I looked up the part number on summit racing http://store.summitracing.com/partde...&view=32&N=115 and it says application 93-97. Does that mean that I can choose to go to vented opti (95-97) and get a double roller with a electric pump? Also would it be worth it to convert to a LTCC or LS1 coil pack system.
Old May 3, 2006 | 12:16 AM
OK so I'm going to go with a electric water pump, vented opti, and cloyes double roller like lethal93ta said. lethal93ta what cloyes double roller are u running?
Old May 3, 2006 | 12:43 AM
Javier97Z28's Avatar
Moderator
The cloyes 3145 is the doubleroller for our cars.
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
phoenix95
Jan 8, 2015 02:44 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
