best stock size replacement pushrod?
Old May 21, 2004 | 12:32 PM
96LT1Fan's Avatar
Looking at dropping GMPP 1.6 RRs into my 96Z. Wanted to know what the best replacement pushrod would be. Are hardened pushrods going to worth the money on a stock cam? If stock pushrods would be best.. what is the GM P/N?
Old May 21, 2004 | 01:25 PM
Revolutionary's Avatar
For about $100 you can pick up a set of Comp Magnum pushrods that will handle any spring pressure on a hydraulic roller and most solid roller setups.
Old May 21, 2004 | 01:43 PM
Brandon94Z28's Avatar
I have a set of hardened push rods from my 94z with 9000 miles on them. They are in perfect shape. I will let them go cheap.
Brandon
greeneyes56@hotmail.com
Old May 21, 2004 | 05:44 PM
96LT1Fan's Avatar
I think I read somewhere that the stock 94-95 pushrods were hardened but the 96-97 rods were not? What's up with that?
Any difference in size or diameter between the two? Does anyone have GM part #'s.
Old May 21, 2004 | 06:54 PM
96LT1Fan's Avatar
I think I found the part # for a set of 93-95 pushrods in one of Shoebox's old posts;
P/N 12371041 (about $21 on GMpartsdirect.com + S&H)
The fact that there are different part #'s for the 93-95 and 96-97 pushrods would definitely lead me to believe that there is some difference between the two. Can anyone tell me why GM would go w/ hardened pushrods but then switch them out for something else in 1996? Seems wierd....
Old May 24, 2004 | 12:34 PM
96LT1Fan's Avatar
Can anyone chime in on this one?
Old May 24, 2004 | 12:42 PM
joeSS97's Avatar
I guess GM decided hardened pushrods werent necessary.They cost more too.FWIW I am running the stockers with a small cam.
Old May 24, 2004 | 04:26 PM
96LT1Fan's Avatar
Does anybody have a P/N for the 96-97 pushrods?
Old May 24, 2004 | 05:33 PM
5.0THIS's Avatar
comp cams chromemoly
HectorM52
Jul 30, 2017 11:46 AM
Jason Short
Jan 19, 2015 06:34 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
97 RedSS
Jun 10, 2003 07:58 PM
