best springs for me?
Old Mar 16, 2007 | 08:32 AM
ZL1modified's Avatar
i am running a stock cam for now but in the future i am going to go with a 305 cam...
i am looking for a spring that can work with both cams...
what spring now would make this possible? (if it is possible)
i'm pretty uneduacated when it comes to spring and cam selection...
Old Mar 16, 2007 | 08:42 AM
Z-RATED94's Avatar
Comp Cams 918 beehives. A little pricey, but well worth the money and piece of mind.
Old Mar 16, 2007 | 12:05 PM
truedualws6's Avatar
Cheaper Option
If you want to same some $$ you can go with the Isky 235-D springs.
They will work with the stock hardware and are good to .550".
Old Mar 16, 2007 | 12:12 PM
BUBBA's Avatar
I would go with some double springs good to 600 lift. E.g. Crane 99893 (only get the whole kit, whatever that number is (on this site somewhere). Or, as someone suggested, go with the behives--- good for over 600 lift.
JMHO, but 550 max might be cutting it too close, especially if you decide you want to with a mild, albeit, little bit bigger cam.
Old Mar 16, 2007 | 03:43 PM
seawolf06's Avatar
Yep, that's what I was about to say.
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
