Best spark plug?
Old Aug 31, 2003 | 01:09 AM
Fux0redImages's Avatar
Best spark plug?
I am tuning up my car I already bought a MSD Coil, MSD 8.5 wires and now I don't know what spark plugs to get. I am thinking either just the AC Delcos or NGK, either way platinum. Give me some opinions here.
Old Aug 31, 2003 | 01:12 AM
Got-LT1's Avatar
i used NKGs with a simlier setup, and didn't really like them. Then I got a bad load of gas and that fuel fouled the plugs, so I switched back to ACDELCOs, and I can't be happier.
Old Aug 31, 2003 | 02:20 AM
RamAir95TA's Avatar
I'm using NGK TR55s, and honestly...I wouldn't use any other plug.
Old Aug 31, 2003 | 03:03 AM
redimpss5's Avatar
what kind of life span can i expect from the ngk tr-55?
Old Aug 31, 2003 | 03:26 AM
RamAir95TA's Avatar
Well...they aren't platinum, so not as long as those. But I'll be damned if the car doesn't run outstanding while they're plugged in my heads. If they do foul, they won't cost you $12 a plug either. You can get a set for under $15.00.
NGK TR55
Old Aug 31, 2003 | 03:31 AM
redimpss5's Avatar
thanks! i am running the bosch plus 4 now and a few people have said they have had problems with them! i just put in a new coil and OMG the car idles so smooth now! i thought it was bad plugs or opti. but i am going to get those ngk's
Old Aug 31, 2003 | 03:36 AM
redimpss5's Avatar
oops, BTW, i found them online at thunder racing for 2 bucks a plug, i guess thats about the right price
Old Aug 31, 2003 | 03:42 AM
RamAir95TA's Avatar
You can get them through Advance Auto Parts for $14.00 a set, if you have one nearby!
Old Aug 31, 2003 | 04:18 AM
X-Jester's Avatar
I run AC Delco platinums, I only paid $6 per plug. The whole set came out to about $49.50 after tax. I wouldn't put anything else in my engine. I have heard good things about NGK TR55's, but nothing that would make me choose them over AC Delco platinums.
Old Aug 31, 2003 | 04:19 AM
96LT14u2Nv's Avatar
NGK's are good plugs. i used to run delcos but for the money, they didnt hold up as well as i hoped. NGK's have done great....and they are only a 1/3 of the cost of delcos
Old Sep 2, 2003 | 06:30 AM
scoobysnax83's Avatar
Yea but who can say that they've put 100,000 miles plus on the the NGK's without a single problem?
By the way, point being that the Delco's are tried and true. On a mostly stock engine, there is no reason to use anything else. I may understand the money issue, but if you have to swap them out in half the time, the money isn't really a factor anymore...
God, I love starting controversy
Old Sep 2, 2003 | 09:31 AM
LeftoverChinese's Avatar
NGK Iridium's are the absolute best in my opinion.
Old Sep 2, 2003 | 09:37 AM
OrionSPL's Avatar
I am using the NGK TR6s and those plugs work well. I have a FEW mods plus nitrous and needed a colder plug. For a less modded ride I would say the 55s are a great plug.
Old Sep 2, 2003 | 12:02 PM
JSK333's Avatar
Autolites also work well and are very inexpensive, like around $1/plug. I forget what the stock heat range is for our cars, but 104 is one step colder and 103 is two steps.
Both of those have worked fine in my stock engine car when running N/A (I went colder because I run nitrous too).
Old Sep 2, 2003 | 12:20 PM
CamaroBoy96Z28's Avatar
I use NGK TR55s and am very happy. Even if they dont last as long as AC Delcos, I'd rather replace the NGKs more often then pay for the Delcos. Doing my plugs is cake so I'm ok with it.
jwade88
Jun 14, 2015 09:38 PM
jayblev95
Jun 7, 2015 04:04 PM
blkWidow
May 3, 2015 08:42 AM
nikko
Apr 20, 2015 07:56 AM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
