Best plugs and wire for stock motor?
What are the best plugs and wires for a stock motor?
Re: Best plugs and wire for stock motor?
I went back with the AC Delco Platinum plugs and a set of ACCEL Extreme 9000 wires. Runs great!
This is a brand new motor through GM, so I wonder if it makes a difference what plugs and wires I use?
I put Taylor Spiro-Pro wires and Delco plugs back in when it was almost stock and had 125k miles. It runs like a champ and am getting upwards of 28-29 mpg on the highway now with 158k.
I don't suppose it really matters for a stock motor but I personally would get accell extreme 9000 because there suppost to have a much higher heat tolerance (good for headers if you get em)
i used the taylor's 8mm and ac delco platinum plugs too, runs great :)
I've heard the Accel wires handling the heat from headers better than the Taylors.
I've been using the NGK Tr55's, and the Taylor OTVC kit from Thunder for some time now and am happy with them.
Delco platinums and accel 300+ race series, runs great but opti starten to die:(
As funny as it may sound to some, if I needed to do wires on my modded engine, I would buy a set of stock GM wires. I also use AC Delco platinums although I've used NGK TR5 plugs in the past and they worked well. Considerably cheaper too.
part number/description 12096439 WIRE KIT list 119.59 net 68.76 5614244 SPARK PLG 7.41 5.11 |
you can still buy a LT1 brand new?
I think I am going to go with AC Delco Platinum plugs and MSD wire.
Which set of MSD wire to get? I want them to fit in the stock location. Checked AutoZone and they have the following: MSD BLACK 31243 $54.99 CUSTOM SET; 90 DEG.; W/LOW PROFILE DISTRIBUTOR; PN 84697;84997;8558; WIRES BELOW HEADER/EXH. MAN.; SUPER CONDUCTOR 8.5MM MSD BLACK 31593 $70.99 W/SOCKET DISTRIBUTOR CAP; SOCKET STYLE; WIRES BELOW HEADER/EXH. MAN.; SUPER CONDUCTOR 8.5MM MSD BLUE 3124 $44.99 CUSTOM SET; 90 DEG.; W/LOW PROFILE DISTRIBUTOR; PN 84697;84997;8558; WIRES BELOW HEADER/EXH. MAN.; RACE TAILORED HELI-CORE WIRES MSD BLUE 3559 $55.99 CUSTOM SET; W/HEI TERMINALS; RACE TAILORED HELI-CORE WIRES MSD BLUE 3127 $69.99 W/180 DEG. HEADERS; RACE TAILORED HELI-CORE WIRES MSD BLUE 3183 $43.99 W/HEI; RACE TAILORED HELI-CORE WIRES MSD BLUE 3159 $55.99 W/SOCKET DISTRIBUTOR CAP; SOCKET STYLE; WIRES BELOW HEADER/EXH. MAN.; RACE TAILORED HELI-CORE WIRES MSD RED 31249 $64.99 CUSTOM SET; 90 DEG.; W/LOW PROFILE DISTRIBUTOR; PN 84697;84997;8558; WIRES BELOW HEADER/EXH. MAN.; SUPER CONDUCTOR 8.5MM MSD RED 32859 $75.99 CUSTOM SET; 90 DEG.; W/MSD FRONT DRIVE DISTRIBUTOR; PN 8720; SUPER CONDUCTOR 8.5MM MSD RED 32149 $76.99 CUSTOM SET; SUPER CONDUCTOR 8.5MM MSD RED 35599 $78.99 CUSTOM SET; W/HEI TERMINALS; SUPER CONDUCTOR 8.5MM MSD RED 30479 $71.99 HEI TERMINALS; WIRES BELOW HEADER/EXH. MAN.; SUPER CONDUCTOR 8.5MM MSD RED 31279 $75.99 W/180 DEG. HEADERS; SUPER CONDUCTOR 8.5MM MSD RED 31839 $68.99 W/HEI; SUPER CONDUCTOR 8.5MM MSD RED 31599 $70.99 W/SOCKET DISTRIBUTOR CAP; SOCKET STYLE; WIRES BELOW HEADER/EXH. MAN.; SUPER CONDUCTOR 8.5MM Also, is this the stock plug wires for our car? DEL Cap, Rotor, Wire Kit 1 per car. PT757 Each $32.99 N/A MODULE-ELECTRONIC IGNITION CONTROL CONNECTOR - 4-WAY FEMALE BLACK - EXC MEXICO LIMITED LIFETIME WARRANTY |
My mechanic strongly recomended NOT to install the msd wires. I bought those originally and ended up taking them back. I gave you the stock plug wire #'s
I've got new AC Delco wires and Bosch platinum plugs in mine.
