Best performance upgrade with strict budget!
Re: Best performance upgrade with strict budget!
Originally Posted by WhyHelloOfficer
I purchased the hot cam kit at cost from a Chevy Dealership (through an employee) and it cost me a little over $600 with all of the gaskets + the cam kit.
Originally Posted by Z95m6
I know but what kind of timing chain are you running? If you say stock, then i'd saying you are running risky parts. Also the guy i was referring to is running a 230/236 so the parts aren't probably gonna be as cheap.
I understand what you're saying though. I am a firm believer in "Do it once Do it right."
do the hot cam kit shoot up to about 315-330rwhp but you will spend more than the 500 dollars the kit cost, plus if you can't do the install yourself that will cost you some big bucks. if not i would go with some gears and the computer tune which would be good for the gear change. get some 373's i know people will say 411's but i love my 373 gears in my 6 speed. and don't worry about the rear i have nearly 400rwhp on my stock 10 bolt with 373 gears.have fun
So prices I think were:
$40 -new stock timing chain/gears from friend
$100 - 1.6 rockers (used)
$110- CC612 valve springs (only thing went cheap on and now I've got valvefloat
) If you go with a smaller cam, you can get away with using these.
$25- Hardened pushrods
$240- Cam
Total is $525, then gaskets, oil, etc were extra.
Ryan
) If you go with a smaller cam, you can get away with using these.$25- Hardened pushrods
$240- Cam
Ryan
$240- Cam
Ryan
$240- Cam
Ryan
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 27, 2015 06:27 AM
