"Best" non-Longtubes?
Re: "Best" non-Longtubes?
AS&M and RK are the same thing. Only real difference is the RK's have oval primary ports vs the AS&M with the head matching D ports. The RK's have a bit less quality coating. SLP's are nice also. I have seen impressive gains from all of these brands. Macs are ok, but I see these three as being a much better alternative to LT's. LT's now come with emission hook ups if you wanted to consider that.
-Dustin-
-Dustin-
I dunno about AS&M but SLP uses stainless steel to construct their headers... and for some reason they are not as popular as the AS&M so you can pick up a set for a little cheaper. Brand new either one is going to set(coated) you back around $800.
Has anyone been able to compare the AS&M plug Access VS the MAC plug access? Also what coatings come with AS&M headers? Looks like i've narrowed it down to those two
The only like i can find on the AS&M was this: http://www.azspeed-marine.com/as19lt1flotu.html didnt see any about midlengths... Anyone have any info on the mids?
i have the rk sports. mine are ceramic coated. i like them, sound nice, look nice, but hang very low with my 3"i hi-flow cat. i have the slp y-pipe and i defitely have many problems with leaks. i had to get it welded shut where the collector meets the y-pipe. i blew up 5 bolts and broke off bolts that had nuts welded onto them. i have also had a bolt come off the header at the heads, but thats probably from the vibrations of the weld underneath. i would say defintely good though, and i still pass emission.
I vote for MAC's.
Here is a link showing the plug access with my MAC's.
http://web.camaross.com/forums/showt...highlight=plug
Dan
Dan
From: Austin, TX or Texas State University at San Marcos
I stand by my AS&M's tride and true.
Check em out at http://www.tbyrne.com/lt1catalog.html click on exhaust and scroll down to them.
they are beautiful set of headers.
Chris
they are beautiful set of headers.Chris
Jason Short
Jul 18, 2013 11:40 AM
