Best LT1 tuning Software????
Ditto TunerCat. It's cheap, works on unlimited PCMs, and if you ever get to the point where you can find new tables, you can add them yourself with their definition file editor!
Zac2003, if you have an OBDI LT1 PCM ('94/'95), with an OBDII connector (16-pin), then yes, TunerCat will work. It's what I use!
Originally posted by Zac2003
JSK, I have a 95 so I believe I do, how can I tell if my pcm is obd1 or 2?
Originally posted by SVT Killer LV
TunerCAT rocks harder than montley crue... Maybe someday I'll get the RT version (just need the romulator). I use TunerCAT and it is a great program.
http://www.tunercat.com/tnr_desc/tnr_desc.html thats the correct link for the tuner I need right??
also if the rt is worth the 30$ I'll go ahead and get it.
Originally posted by 97SS0594
so my opti crap will line up?? and the whole wireing harness?? so probably need to find a 95 pcm then or will any work??
