Best Lt1 Plugs???
Old Dec 2, 2006 | 12:09 AM
ev95355's Avatar
Best Lt1 Plugs???
Thats it, what do you guys run???
Old Dec 2, 2006 | 12:38 AM
1FstFormulaV8's Avatar
NGK TR55's seem to be a board favorite. Try using search, plugs are discussed quite often...
Old Dec 2, 2006 | 01:21 AM
Zeueses 97 RamAir's Avatar
ac delco
If your going to drive every day i would go with ac delco platniums, i have used both ngk you would have to change out at every 15k ac delcos about 70k
Old Dec 2, 2006 | 09:23 AM
hotrod18_69's Avatar
TR55's
Old Dec 2, 2006 | 09:45 AM
Colin91Z's Avatar
I've had pretty good luck running NGK TR6s over the years
Old Dec 2, 2006 | 09:48 AM
sko_spo's Avatar
try these--http://www.boschautoparts.com/Products/SparkPlugs/IrFusion.htm
and tell us how it goes.
Old Dec 2, 2006 | 10:40 AM
2000GTP's Avatar
Can't go wrong with NGK TR-55s or stock Delco platinums. The NGK TR-55s are cheap, but with the copper conductor, they will wear out faster and require to be changed sooner. The Delco platinums are about three times as expensive, but will last much longer.
Old Dec 2, 2006 | 11:10 AM
JP95ZM6's Avatar
4 or 5 of my Delco Platinums were missing one or both of the platinum pads after about 35K miles in stock LT1!! I hate to think what those nasty little pieces of metal could do if they didn't spit out the exhaust, and the huge plug gaps that result can't be good. I won't run em again.
Old Dec 2, 2006 | 11:12 AM
69gto96z's Avatar
I love my TR55's, and plug changes are a lot easier with headers vs. stock manifolds, so having to change my plugs every 15k miles is no big deal to me.
mritter1965
Feb 9, 2015 07:01 PM
cmdeshon
Dec 27, 2014 10:06 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
Camaro90RS
Jul 23, 2002 07:57 AM
