best lifters and pusrods for:
Old Aug 11, 2008 | 11:56 PM
sn8ke eatr's Avatar
the 355 im in the process of building. im using a mild comp cc305 cam, and have crane 1.5 inch gold rockers. the heads are unmilled and ill be using a factory thickness head gasket so the pushrods will be the stock legnth. so my question is which brand would you suggest to use for my combo without breaking the bank.
also, i need a timing chain set, can anyone reccomend me a good one?
Old Aug 12, 2008 | 09:28 AM
mdenz3's Avatar
The pushrod legnth will also be dependant on the lifters you choose.
Old Aug 12, 2008 | 04:01 PM
sn8ke eatr's Avatar
oh i didnt know that, mind pointing me in the right direction of which would go together nicely?
Old Aug 12, 2008 | 04:15 PM
Rising Phoenix's Avatar
Just get the chromoly one piece pushrods from any of the major brands, and the "LS7" lifters. Best bang for the buck!
Old Aug 13, 2008 | 08:52 AM
Z-RATED94's Avatar
Just buy the stock replacement gears and chain. Many have gone this route without a problem.
Old Aug 14, 2008 | 11:15 PM
sn8ke eatr's Avatar
where are you guys getting the "stock replacement" parts from? i went to napa and they didnt carry this in oem brand and i imagine a dealer will charge me out the ***
Old Aug 15, 2008 | 04:24 AM
RallyBoy1's Avatar
Check out the c-3039 at summit. It is the cloyes timing chain kit.
Old Aug 15, 2008 | 04:45 PM
sn8ke eatr's Avatar
would this work for my car? :
http://store.summitracing.com/partde...7&autoview=sku
i was told 93 is different for some reason
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
